Spark plug test - Mustang Evolution
Old 09-13-2006, 02:39 PM   #1
Send a message via AIM to 98StangGT
Spark plug test
How do I test my plugs or wires or coil packs, like when the car is running, do I unplug each plug at a time? from the engine, or coil pack? thnks
98StangGT is offline   Reply With Quote
Old 09-15-2006, 06:34 AM   #2
DarkShadow's Avatar
Send a message via AIM to DarkShadow
Re: Spark plug test
I would unplug from the plug itself as unplugging from the packs can cause sparking and possibly mess up the coil (if it's not already).
Do you have a missfire? If so, you can either pull each plug out and look at them to see if it's the plugs causing it. If they are not fouled or damaged, than start pulling off wires one at a time. If they make the missing worse, then the wire you pulled is good, if it made no change, than that wire was bad and you need to replace it. There's no real way to test coil packs, some parts stores might say you can, but it is really a BS test, they could pass it for having continuity, but it could still be bad anyway.
DarkShadow is offline   Reply With Quote
Old 09-19-2006, 03:49 PM   #3
Re: Spark plug test
I changed my plug wires and coil packs and my car runs AWESOME!!!! no more bucking, or missing
Blew a spark plug Mustangfan2003 1996-2004 Mustang GT 3 09-18-2009 11:16 AM
Spark Plug 1234 The Bar 9 08-07-2008 09:23 PM
spark plug ? foxbodym 1979-1995 Mustang GT 5 07-17-2008 05:02 PM
spark plug choice bigpomps Pre-2005 V6 Mustang 4 05-01-2005 08:32 PM
Spark Plug Wires Laser02 Pre-2005 V6 Mustang 32 11-08-2004 08:30 AM
12:52 PM
