whats a heater coil - Mustang Evolution
Old 09-24-2006, 10:47 AM   #1
Send a message via Yahoo to stovalini69
whats a heater coil
recently my mustang is acting up. ive had to add water to my radiator because my low fluid symbol comes on and the winshield is fogging up. my friend said it was my heater coil. has anyone heard of that or know where to get one?
stovalini69 is offline   Reply With Quote
Old 09-24-2006, 10:51 AM   #2
Zim
You want to **** me?
Zim's Avatar
Re: whats a heater coil
I dont really know what they are, Im pretty sure it has to do with something in your a/c though.
I like toys
Old 09-24-2006, 10:53 AM   #3
Zim
Zim's Avatar
Your Ford heater core keeps the inside of your car toasty and warm. A heater core is a series of coils attached to the radiator by hoses. Coolant flows from the radiator through the heater coil. The surface area on your core’s coils heats up, allowing hot air to be sucked into your car. You control the amount of heat that your Ford heater core releases into your car by adjusting the heat levels and blower levels on your temperature panel. Maintaining your heater core is relatively easy. Your Ford heater core will be automatically taken care of when you have your cooling system serviced. Consult your owner’s manual for your maintenance schedule. There are several indications that you might have a problem with your heater core. If you turn on your heater and your car just does not seem to get warm enough, you may have a heater core problem. If you turn on the heater and it just does not smell right, you might have a problem. Obviously, if you find coolant inside your car, you probably have a leak. When any of these problems occur, do not ignore them, particularly if you are coming up to the winter season. Having an effective heater is imperative for the comfort of you and your passengers.
Ford Heater Core - Ford Heater Core Replacement | Free Shipping
I like toys
Old 09-24-2006, 11:01 AM   #4
bbunt302's Avatar
Damn... the dreaded heater core. Feared and hated by mechanics everywhere.
Scary stuff.
Old 09-24-2006, 11:06 AM   #5
how hard is it to replace and how much does it cost to do this.
Old 09-24-2006, 11:18 AM   #6
bbunt302's Avatar
It's a pain to replace. I know that for the foxes, it requires removal of the dash. Yup. That's right. The entire dash. I really have no idea how much a shop would charge you to swap one out.
Whatever you do... don't buy a cheap Autozone-ish heater core for a replacement. Go to Ford and get the factory part. This isn't something you're gonna want to do again.
Here's a link that shows how to swap one out on a '86 GT: 5.0 Stangs - Late Model Mustang Restoration Specialists
Scary stuff.
Coil on Plug Ignition Coil Pack Set (8) 99-04 Mustang W/ Wiring Harness Cobra GT Mustang Parts for Sale and Wanted 7 12-28-2008 10:59 PM
My heater scuks in fumes when I turn on the heater jaynez31 Pre-2005 V6 Mustang 3 02-08-2006 07:44 PM
'65 Heater controls Ken Classic Mustangs 7 02-04-2006 10:57 PM
Heater cores Ponycarman Pre-2005 V6 Mustang 0 11-08-2004 08:10 PM
whats the better rpm curve?/whats a good car choice? Thomas91169 The Bar 7 12-05-2003 11:24 PM
09:33 AM
