ABS and Traction control light on - Mustang Evolution
Old 09-30-2006, 03:46 PM   #1
Thumbs down ABS and Traction control light on
Can anyonr help me? My abs and traction control light came on and stay on, all the time(as long as the car is running). A friend of mine cleared the codes for me, but as soon as you start the car, they come back on. The only code found was a shorted brake fluid level sensor. Does this sound like something that could cause this? He could not get into the abs system to see if any codes were in it, so I am trying to find out any info I can. I called Ford, and they only list a brake fluid level switch. Same thing? Any help would be appreciated. Thanks.(2001 Mustang GT all stock coupe)
rugman1969 is offline   Reply With Quote
Old 09-30-2006, 04:09 PM   #2
MonteCitan's Avatar
Re: ABS and Traction control light on
disconnect the sensor and scan again -- if it still says shorted, the faults could be anything from the wiring to the PCM itself, if it trips a different code, (a code for open circuit..?) try replacing the switch, and yeah the sensor could be listed as a switch
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
abs and trac control light. powerstroker Pre-2005 V6 Mustang 3 05-21-2009 01:56 PM
Brake Light & ABS Light on. stevinas 2005-2010 Mustang GT 1 06-26-2008 03:21 PM
Traction control? braumab General Mustang Discussion 30 12-21-2007 02:50 PM
Traction Control Q wrecked2001 Pre-2005 V6 Mustang 12 03-20-2006 06:57 PM
traction control greenpony02 Pre-2005 V6 Mustang 28 05-02-2005 10:57 PM
05:53 AM
