Brakes! - Mustang Evolution
Old 10-15-2006, 08:29 PM   #1
Send a message via AIM to 98StangGT
Brakes!
My brake light keeps comin on and off like every minute it will flash on and off?? what could be the problem?
98StangGT is offline   Reply With Quote
Old 10-15-2006, 10:37 PM   #2
Thomas91169's Avatar
Re: Brakes!
check your fluid level lately?
-Thomas-
Old 10-16-2006, 08:48 AM   #3
MonteCitan's Avatar
Re: Brakes!
^^^ what he said
if fluid level is low might be time to check your front or rear brakes..
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 10-16-2006, 08:54 AM   #4
Stumpy's Avatar
Re: Brakes!
If it's good, try cleaning the float sensor with some brake cleaner. If debri builds up around it will stick. And if that's the case, change your fluid.
~Roman~
2003 Mustang V6 Vert with a Flowmaster Super 40 series dual exhaust
I'm not a target in the sights of your mercy. I've never asked for anything. I'm not asking now.
Stumpy is offline   Reply With Quote
Old 10-16-2006, 09:07 AM   #5
Danger Dude's Avatar
Re: Brakes!
Here is what you need to do
1. Check fluid, if low fill to proper level. If full schedule a brake fluid change.
2. Break fluid can absorb 3% to 5% water every year. If you have not ever changed the brake fluid nor the prior owner you could have 20% water in the system and a build up of water borne trash might be causing problems
3. It is best to change fluid every 2 to 3 years max.
4. So even if it is full or needs fluid and it has not been changed in years get a fluid change ASAP
Old 10-16-2006, 11:54 AM   #6
Re: Brakes!
it could also be problems with the ABS package, but i wouldnt jump to that conclusion until the easier fixes are cancelled from the equation.
-Thomas-
Old 10-16-2006, 01:34 PM   #7
Justin's Avatar
Send a message via AIM to Justin Send a message via Yahoo to Justin
Re: Brakes!
i have something wrong with my brakes too...not the same thing though....when i stop and start going it seems like my brakes are still barly thouching the rotor and makes a sound and the faster i start going the faster it does.... then it quits after about 4 or 5 times..
http://www.mustangevolution.com/forum/signatureuploads/sigpic5474_2.gif
(Project "TORQUE"):burnout:
Mods - Off Road H w/ Flowmaster 40s and 3" x 22" Tips, Shiftkit, Shorties, and 4.10s
Soon to come - UDPs, Off Road X-Pipe, A/T Cooler, and 03' Cobra Rims
Club - Tha Crew Leader of Muscle Car Division
Justin is offline   Reply With Quote
Old 10-16-2006, 01:57 PM   #8
Re: Brakes!
What kind of sound??? Have you checked your brakes to see if they need changing??? To stop break noise the best thing is when you do finally change the brakes make sure they are chamfered. This makes for a much more quite pad. The pic below is of some brake pads you will notice the 2 center pads are tapered on the ends. This is called chamfer type pads.
Name:	chamfered Brake_pads.jpg
Old 10-16-2006, 02:39 PM   #9
Re: Brakes!
get your rotors turned. 5$ a piece at pep-boys with a 20 minute turn around time for all 4 (given you have them off the car already). sounds like theyre warped.
-Thomas-
Old 10-16-2006, 02:44 PM   #10
Stumpy's Avatar
Re: Brakes!
But does it shake when braking? Mainly a vibration in the steering wheel?
~Roman~
Old 10-16-2006, 03:02 PM   #11
Justin's Avatar
Re: Brakes!
yea it does shake.....i just changed the brakes on the back....it sounds like its commin from the back....we dont have a pep boys around here....u know how much it would cost at mineke??? thanks for all the help
Old 10-16-2006, 03:07 PM   #12
Stumpy's Avatar
Re: Brakes!
Sounds like you may have two different problems. Steering wheel vibe is typically front rotors. Noise in the rear could be misaligned caliper piston. Or sluggish caliper pin, i.e. caliper slide is sticking hold a little bit of pressure to the rear brakes.
~Roman~
Old 10-16-2006, 03:22 PM   #13
Justin's Avatar
Re: Brakes!
its anoying as hell...how do i fix the back brake problem....ill get my rotors turned and i think that will fix the shaking problem
Old 10-16-2006, 03:50 PM   #14
Stumpy's Avatar
Re: Brakes!
Pull the rear calipers back off and lube the slide pin. Also make sure the piston is level and not crooked. Uneven pressure will cause unwanted grabbing and noise and cause the pads to wear unevenly and prematurely.
~Roman~
Old 10-21-2006, 10:37 PM   #15
Re: Brakes!
You might check to see if e-brake lever is fully disenguaged at the rear wheel, also check hand brake lever is all the way off, if there is slack in cable adjust it.
Ryano is offline   Reply With Quote
Old 10-23-2006, 04:35 PM   #16
rocknbronco's Avatar
Re: Brakes!
if the turn the rotors make sure they are at a safe diameter I never turn em I always replace em.How is the surface of the rotors front and back sides?take off the wheels and check the thickness of the pads also have someone scan your car might tell you whats going on kinda sounds like abs issues wit the rotors are warped
Mustang wanted for here...
rocknbronco is offline   Reply With Quote
BRAKES DMAC General Mustang Discussion 5 02-18-2008 08:26 PM
Brakes mongolchuck 1979-1995 Mustang GT 1 01-12-2008 03:49 PM
brakes.. Fishers Stang Pre-2005 V6 Mustang 14 01-13-2005 06:32 PM
Brakes V6STANG007 Pre-2005 V6 Mustang 23 10-13-2004 04:32 PM
Brakes....... SexyStang Pre-2005 V6 Mustang 3 05-05-2003 09:03 AM
10:09 PM
