Rear end leaking.... - Mustang Evolution
Old 06-13-2010, 09:24 PM   #1
allnotch's Avatar
I have a 02 gt and the rear end was leaking before so I replaced the pionion seal and seemed ok for a month or so and now it seems like its leaking from somewhere else. The seal that I replaced isnt wet with fluid or anything but I can see thats it wet on the axle and the exaust and all over underneath where the chunk is, any ideas?
allnotch is offline   Reply With Quote
Old 06-13-2010, 10:33 PM   #2
1234's Avatar
Re: Rear end leaking....
you check the cover gasket yet?
Old 06-14-2010, 08:18 AM   #3
most of them leak over the pumpkin cover~ generally there is no seal there, just RTV or what not and if ANY oil is on the edge it wont seal good, and over time it can just leak
Old 06-14-2010, 05:10 PM   #4
allnotch's Avatar
I know its not leaking from the bottom of the cover but it might from the top of it. Theres really no where else for it to leak from is there?
Old 06-14-2010, 07:42 PM   #5
1234's Avatar
Input shaft seal, axle seals, and the cover. Unless you axle housing is cracked.
Old 06-14-2010, 08:25 PM   #6
Mustang_GT's Avatar
I will just change the seal, I bought mine in autozone 11bucks
2002 Mustang GT, Full Roush kit, Side Exhaust, Flowmaster 40 Series, BBk cold Air intake.
Mustang_GT is offline   Reply With Quote
Old 06-16-2010, 05:10 PM   #7
DarkShadows's Avatar
the vent can actually leak too. ask me how i know
March 2010 Mustangevolution Mustang of the Month 1st eva biatch!
DarkShadows is offline   Reply With Quote
Old 06-16-2010, 07:58 PM   #8
allnotch's Avatar
How do you know? Is the vent towards the front of the chunk or towards the pass. side?
Old 06-16-2010, 08:31 PM   #9
67mustang97's Avatar
Region: Vermont
It's on the passenger side right under the exhaust. They come out easy with a wrench, make sure it's not plugged and the cap moves freely. Same thing happened on my 97.
Old 06-17-2010, 02:31 PM   #10
1234's Avatar
sorry forgot about the vent.
Old 06-17-2010, 05:06 PM   #11
jimmy_beaner's Avatar
Region: Iowa
My rear seems to have started leaking as well I didn't get a chance to take a nice close look at it yet. The guy at the exhaust shop said it looked like the pinion seal.
Old 06-17-2010, 10:04 PM   #12
allnotch's Avatar
Ill check the vent this weekend and see if thats whats going on, but from the sounds of it that just might be it. Ill check back in and share what I found. Thanks
Old 06-28-2010, 06:10 PM   #13
allnotch's Avatar
Well no luck. The pionion seal looked dry, vent was dry, the back cover was wet a little wet around bottom and the bolts were a little loose but thats it. I dont think the bottom on the pan leaking would get to the front of diff and on the mufflers could it?This only seems to happen when I'm in the gas for a little.
Old 06-28-2010, 08:56 PM   #14
Region: Vermont
Is your diff cover pitted? I've seen em leak through the cover before. Hopefully it's just the bolts being loose.
8.8 rear end tigerfan2771 Pre-2005 V6 Mustang 20 12-12-2008 05:08 PM
97 v6 rear end 97 stang Pre-2005 V6 Mustang 1 10-09-2008 11:22 AM
Leaking rear Calumus 1996-2004 Mustang GT 4 09-19-2008 05:41 AM
99+ GT rear end jimmy_beaner Mustang Parts for Sale and Wanted 2 05-13-2005 02:33 PM
8.8 Rear End ttpancakes Mustang Parts for Sale and Wanted 8 07-20-2004 07:39 PM
09:58 PM
