Car wont stay running - Mustang Evolution
Old 06-13-2010, 10:58 PM   #1
Mustang1804's Avatar
Send a message via AIM to Mustang1804 Send a message via Yahoo to Mustang1804
Earlier I went to go pick up my take out and I tried to start my car and it started then slowly died down and I repeated this about 7 times and even tried to rev the engine and it reved then the car continued to slowly die down. The spark plugs are brand new as well as the alternator and idk I have to change the grommet (fuel filler) only but idk I cant think of what the problem could possibly be. Need advice, opinions. Thank you in advance!!!
Mustang1804 is offline   Reply With Quote
Old 06-14-2010, 10:44 AM   #2
Tape's Avatar
Re: Car wont stay running
when is the last time you changed the fuel filter?
Tape is offline   Reply With Quote
Old 06-14-2010, 02:48 PM   #3
It has been awhile since I had the filter changed, im gonna go ahead and change the filter, if this isn't the problem u have any other suggestions?
Old 06-15-2010, 03:51 PM   #4
Tape's Avatar
I would do the filter first because it's cheaper, if that doesn't fix it you need to make sure the pump is good. you can disconnect the fuel line at the motor and put the fuel line in a glass jar, turn the key to where the dash light come on and you will see if the pump is good or bad, if the fuel is filling up the jar then the pump is good, you can also do this before you change the filter.
Old 06-15-2010, 04:04 PM   #5
Ok thank u much, I will definitely try these suggestions, ill keep u posted. Thanks again.
Old 06-17-2010, 10:59 AM   #6
I found out what was wrong. I didn't change the fuel filter but the problem was actually the IAC (Idle Air Control) valve and I should have known since my rpm been acting a little screwy the past few weeks. I just had the shop down the street fix it. They kind of jived me on the labor a little bit but it is what it is. Thanks a lot for the suggestions. Appreciate it the help.
converted to maf now car wont start!! juced302 1979-1995 Mustang GT 9 02-25-2010 06:52 PM
Car wont start iwannagofast 1996-2004 Mustang GT 3 03-03-2008 09:34 PM
car wont shift out of park Kyle Pre-2005 V6 Mustang 19 06-03-2005 02:10 PM
Car wont start!!! eNvy Pre-2005 V6 Mustang 5 04-29-2004 07:19 AM
Car wont start, help: Rellik Pre-2005 V6 Mustang 28 11-30-2003 02:05 PM
04:31 AM
