4.6 sohc cam timing - Mustang Evolution
Old 11-14-2006, 07:03 PM   #1
4.6 sohc cam timing
I just read an article in MM&FF mag. about cam timing on the 4.6. They were saying that the cam timing is not matched between the left and right banks.
They say that by matching the cam timing between the two sides to the retarded side can in crease HP by 20+ HP.
Has any one ever done this and how did you go about it.
The mag. wrote about checking the compression and matching the high psi to the low by retarding the timing on the high side. Filing the key is one way.
Thanks
Jeff
microflight is offline   Reply With Quote
Old 11-27-2006, 07:57 PM   #2
Re: 4.6 sohc cam timing
took the words right out of my mouth, as soon as I read that article I noticed a little idle roughness in my car and wondered if that had anything do do with it. good call.
B
2000 Mustang GT
Black on Black
Best ET-13.794@101.2
Rwhp-246 Rwtq-282
bsmith782 is offline   Reply With Quote
Old 11-27-2006, 08:37 PM   #3
I still haven't gotten an answer if ford did this for a reason or not?
Old 11-27-2006, 09:35 PM   #4
Thomas91169's Avatar
i dont know how retarding timing would gain power.
-Thomas-
Old 11-28-2006, 08:35 AM   #5
I dont think it was retarding the timing for the sake of gaining hp, just to match the two sides of the engine togather for a more efficient power plant.
B
2000 Mustang GT
Black on Black
Rwhp-246 Rwtq-282
Old 11-28-2006, 02:10 PM   #6
bsmith, you are correct it is not the advance or ****** of the timing but the matching so that both sides are making the same power.
Old 11-28-2006, 08:21 PM   #7
if it was really more efficient, i doubt it would get overlooked at the factory.
gotta remember, there is a reason they have one side slightly advanced than the other. They dyno every little chance in the motor, so if they do one run at even then one guy goes "hey lets degree one bank more advanced and see what happens!" so obviously there is a method to their madness.
-Thomas-
Old 11-29-2006, 07:27 AM   #8
ford favors drivability and reliability over hp/tq numbers so they might have done it to make it more smooth.
Old 12-13-2006, 01:10 PM   #9
It wasnt an issue out of the factory, just as the 4.6 ages.
B
2000 Mustang GT
Black on Black
Rwhp-246 Rwtq-282
Old 12-13-2006, 04:32 PM   #10
B
ah yeah that kinda changes everything.
-Thomas-
Difference between SOHC & OHV jwalthersoccer Pre-2005 V6 Mustang 20 12-30-2009 02:55 PM
4.0 SOHC... All fords the same? FourO Pre-2005 V6 Mustang 1 10-17-2009 02:19 AM
1994 3.8 V6 conversion to 1997 4.6 SOHC Babydoll 1996-2004 Mustang GT 5 07-20-2009 06:28 PM
New SOHC Intake Manifolds JROC 1996-2004 Mustang GT 4 10-04-2006 12:11 PM
Cam Cores needed for RDMotorsport cam GP RGR Mustang Parts for Sale and Wanted 3 03-05-2005 05:53 AM
08:13 AM
