Lowering springs - Mustang Evolution
Old 11-26-2006, 10:56 AM   #1
Kryptonite's Avatar
Lowering springs
Ford Racing Lowering Spring Kits: FMS-M-5300-B - summitracing.com
Are these good ones to go with?
Kryptonite is offline   Reply With Quote
Old 11-26-2006, 02:17 PM   #2
Re: Lowering springs
Those won't lower the car very much, but yes, they are a decent spring. Most people looking for a good budget spring go with what is referred to as a "C spring", those are referred to as "B springs"
Old 11-27-2006, 08:07 AM   #3
it all depends on what you want, i personally would only go with C springs from ford. You most definatly wont be happy with only an inch drop~ but when you start to go over 1.5 inches you run into issues. Look into Maximum Motorsports :: The Leader In Mustang Performance Suspensions for all your suspension needs, they are the best out there, their H&R springs are what im going with, also whats the point of going with a lower spring if the spring rate sucks...
you should also get the mm 4 bolt caster/camber plates, dont go cheap on cc plates.
Old 11-27-2006, 03:29 PM   #4
Kryptonite's Avatar
what is the difference between c and b springs? and i'm only going for the look.
Lowering Springs explicitrock Mustang Audio & Video 3 04-14-2010 07:59 PM
Lowering Springs MRACING 2005-2010 Mustang GT 1 01-11-2010 04:11 PM
lowering springs jroc07gt 2005-2010 Mustang GT 22 05-19-2009 02:13 PM
Lowering Springs douGT 1996-2004 Mustang GT 10 02-28-2005 11:16 PM
FRPP Lowering Springs - G Springs Stangthang Pre-2005 V6 Mustang 9 02-23-2005 04:57 PM
10:53 PM
