Brake light coming on and rear end - Mustang Evolution
Old 12-02-2006, 11:17 AM   #1
ridenmystang's Avatar
Ok so lately when I got to stop my brake light comes on. Plus I think my rear end is starting to mess up. It feels like it jumps. Now it could be from me catching seconds every wear I go haha. Its been doing it for awhile but seems to have gotten worse. I was wondering if the brake light coming on when I start to stop has a connection with my rear end.
One wicked 03 GT FOBRA
ridenmystang is offline   Reply With Quote
Old 12-02-2006, 12:19 PM   #2
1 bad ass stang's Avatar
Re: Brake light coming on and rear end
first low brack fluid @ then check your u-bolts on your rear end thats what I would try first.
1 bad ass stang is offline   Reply With Quote
Old 12-02-2006, 12:21 PM   #3
brake fluid not brack fluid
Old 12-02-2006, 01:23 PM   #4
bbunt302's Avatar
Yeah, it just about has to be because of low break fluid.
As far as the rear end "jumping", does it do this most when you first start driving the car? If so, it could just be your tires. I imagine you have Z-rated tires. Tires with soft compounds like that have a tendency to "shake" when they are cold. Once they get warmed up after driving a minute, the problem should go away though.
Scary stuff.
Old 12-02-2006, 02:39 PM   #5
Thomas91169's Avatar
1) brake fluid is low.
2) solid rear sucks. mine jumps all over the ****ing place where the same roads the cobra doesnt. reason why im switching to IRS on the GT.
-Thomas-
Old 12-02-2006, 03:18 PM   #6
Well if I let off the gas it jumps. It jumps even when I press the gas.
Old 12-02-2006, 04:08 PM   #7
Zim
You want to **** me?
Zim's Avatar
Uh, no.
Solid rear does not suck... what sucks is the half *** engineered piece of **** Ford calls an IRS.
I like toys
Old 12-02-2006, 04:08 PM   #8
Calipers seizing up?
Old 12-02-2006, 06:07 PM   #9
MonteCitan's Avatar
so it 'slams' into coasting/slams when you get back on the gas? is it a clunk or a jerk? and is your car auto or manual trans?
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 12-02-2006, 07:54 PM   #10
Originally Posted by Zim View Post
Uh, no.
you go ahead and keep telling yourself that
-Thomas-
Old 12-02-2006, 08:28 PM   #11
Zim
Zim's Avatar
Likewise, "all those cobra guys" dont swap out their IRS for a solid rear for no reason...
I like toys
Old 12-03-2006, 04:11 AM   #12
bbunt302's Avatar
You don't quit, do you?
Good, because I don't either.
The IRS in the 99-04 Cobras is well known for its amazing capability to suck.
Scary stuff.
Old 12-03-2006, 09:28 AM   #13
MonteCitan's Avatar
don't hijack this thread dangit.. back on topic :: see my post above, riden..
Old 12-03-2006, 11:53 AM   #14
bbunt302's Avatar
U-joints would be my next guess.
Also, have you swapped the gears yet? If so, maybe they weren't shimmed absolutely correctly.
I suppose the calipers seizing up could also cause it like Brent mentioned, because from what I've seen the 99+ rear calipers seem to have a history of doing so. Check your rear rotors and look for any signs of unusual wear, mainly any type of groove being cut into the rotor. If this was the case though, you'd probably be experiencing more symptoms than you are (like a horrible grinding/scraping noise).
Scary stuff.
Old 12-04-2006, 11:29 AM   #15
Wel I put some brake fluid in and the light stopped coming on haha. My stupidity Now at least I know to check it But something in the rear end keeps clunking still. Im goin to have to go get it checked out somewhere.
Old 12-04-2006, 02:06 PM   #16
cause theyre usually strip only cars, or cars that see little street use. at the power level there isnt enough R&D in IRS to handle those stresses, so most go with a solid rear thats been in use for almost half a century.
good, dont quit.
Prove why it sucks. Prove to me why Solid Rear has any advantage in anything other than a fully built drag application. Prove to me why guys with drag radials and a IRS brace are outlaunching most AWD cars and having equal 60ft's as some tubbed and chubbed big blocks. Black 04 cobra at the track with DR's and IRS brace was running 11.4's consistently with a 1.6-1.7 60ft. can you do that with DR's? youd prolly be lucky to get a 1.9 or a 2.0 with solid rear jumping all over the place.
I guess thats just the mentality of those still stuck in their 5.0 world.
-Thomas-
Old 12-04-2006, 03:03 PM   #17
Stumpy's Avatar
~Roman~
2003 Mustang V6 Vert with a Flowmaster Super 40 series dual exhaust
I'm not a target in the sights of your mercy. I've never asked for anything. I'm not asking now.
Stumpy is offline   Reply With Quote
Old 12-04-2006, 03:53 PM   #18
Damn just tell me whats wrong with my freking car plz. I was stopped at the red light today and let off the brake to ease up and felt a slight Clink.
Old 12-04-2006, 03:55 PM   #19
Stumpy's Avatar
is there any slipping?
~Roman~
Old 12-04-2006, 04:03 PM   #20
Haha I dont know Im just goin to have to get it checked out somewhere. I can be on the gas and let off and it clunks. I dont know what it means.
Old 12-04-2006, 04:11 PM   #21
Stumpy's Avatar
u joint might be slightly loose. good luck.
~Roman~
Old 12-04-2006, 04:31 PM   #22
Its a GT thing. Get used to it. Theres alot of drivetrain slack in these cars. lets see, i have a clunk when:
1) put it into gear at a light
2) shifting into a higher gear under 3000rpm in 2nd and 3rd.
3) any quick variation of throttle in lower gears (2 and 3) above 1/2 throttle.
4) 1st gear in traffic when letting off or getting on the throttle anything under 1/4 throttle.
5) clunk in reverse
6) random clunks
7) letting off the throttle in any gear and then going WOT instantly afterwards gets a nice clunk
-Thomas-
Old 12-05-2006, 10:40 PM   #23
Zim
Zim's Avatar
Sounds like play in the U-joints... check those out.
I like toys
Old 12-05-2006, 10:41 PM   #24
Zim
Zim's Avatar
Well, there shouldn't be. Sounds like yours is broken too. Check out the u-joints sheila
I like toys
Old 12-05-2006, 11:51 PM   #25
did mine when i first got the GT, as i thought thats all it needed, especially with 75k on the clock. didnt change a thing.
-Thomas-
Old 12-06-2006, 12:46 AM   #26
Zim
Zim's Avatar
sounds like yours has bigger issues then
I like toys
Old 12-06-2006, 01:50 AM   #27
seriously not to hijack the thread again but my both my buddies 95 and 89 stang did it, another local guy with a 98 does the clunk. numerous posts about the clunk on every mustang site leave me to believe its just a mustang thing. Even the cobra does it if i get lazy on my shifting, it could very well be the 12mm bolt issue but its still another one of those "chalk another one up for fords better idea".
I believe my moan is coming from my drivers side rear caliper. for ****s and giggles i re-turned the rear discs and no moan whatsoever, for a week. then it came back. Remember back a while ago i replaced the rear calipers because i thought they were seized but in reality i just needed the ford caliper tool to stick the piston back in? the rears are all new items, brake pads, rotors and caliper were all replaced and i believe they are whats causing the moan, prolly just ****ty remans (they are from autozone). Its either that, or my axle bearings, which from what i hear, would only become noticeable at a certain speed.
-Thomas-
Old 12-06-2006, 08:14 AM   #28
check the LCA/UCA bolts as well if they are loose (or missing) it can cause the rear end to shift around and what not.
Old 12-06-2006, 09:41 AM   #29
MonteCitan's Avatar
my '02 did it only if I was engine braking in a lower gear.. (3rd for example) then slammed the gas... a momentary shift of power would cause a jerk/clunking noise.. its everything spinning one way suddenly going the other, but it was not excessive at all.
My 92, which I beat to hell and back does not do this since I rebuilt the rear, my 89 never did it period. your friends 98 needs work too
Old 12-06-2006, 10:34 AM   #30
fords "fix" for bad geometry design in the live axle setup used since forever (up to 04) was softer rubber bushings so you sacrifice rigidity for sloppyness.
Old 12-06-2006, 11:13 AM   #31
yeah no, its not excessive enough for me to get annoyed with it, but its just "there" sort of things.
and yeah, his 98 is tboned now, so that fixed that.
-Thomas-
Old 12-13-2006, 02:07 PM   #32
maybe its just alittle backlash?
B
2000 Mustang GT
Black on Black
Best ET-13.794@101.2
Rwhp-246 Rwtq-282
bsmith782 is offline   Reply With Quote
Brake Light & ABS Light on. stevinas 2005-2010 Mustang GT 1 06-26-2008 03:21 PM
battery light coming on.... x99xstangxx Pre-2005 V6 Mustang 11 07-29-2007 02:31 AM
Looking a GT Rear Bumper / Right Rear Tail Light - 99-03 Model KrazyPony Mustang Parts for Sale and Wanted 18 07-29-2004 12:33 AM
E-Brake Light Black95GT Pre-2005 V6 Mustang 5 10-09-2003 09:34 PM
07:03 PM
