Convertible Top Button Quit Working - Mustang Evolution
Old 07-05-2010, 08:09 PM   #1
So, I got in my car to come to work tonight and I tried to put my top down and the button is not working. I do not hear the top motor or anything. The top was working before the weekend with no problem. What could the problem be? I am hoping it is something cheap and simple to fix. I tried pulling the e-brake up and down as well as trying the button several times. Any help would be greatly appreciated. Thanks is advance.
SuperDave2010 is offline   Reply With Quote
Old 07-05-2010, 08:52 PM   #2
hottcobra's Avatar
Re: Convertible Top Button Quit Working
check the fuse first. If it's good. See if your getting power to the top motor when you press the button.
Old 07-05-2010, 09:48 PM   #3
Check the fuse first as mentioned. If the fuse is good I would pull the button and check to make sure it's completing the circuit.
I also believe there is a relay for the button somewhere and of course the e-brake relay to tell it when it can operate.
Old 07-06-2010, 09:12 AM   #4
yea if the sensor that checks to let you press the button that waits for the E Brake handle to be up is bad it wont let you put the top down.
convertible top pipeguy 1996-2004 Mustang GT 13 07-26-2008 08:36 AM
keyless entry quit working archer379 Pre-2005 V6 Mustang 7 09-19-2005 03:39 PM
Convertible top V6STANG007 Mustang Audio & Video 12 08-24-2004 08:32 AM
Cruise quit working...... WhiteStang99 Pre-2005 V6 Mustang 5 04-08-2004 05:25 PM
08:43 AM
