brand of brake pads? - Mustang Evolution
Old 12-14-2006, 11:52 AM   #1
jimmy_beaner's Avatar
Region: Iowa
which of these brands is ok for brake pads?
Auto Parts and Accessories Catalog - 2002 Ford Mustang Brake Pad Set
naturally, I would love the ones that are $32 to be 'ok' but I doubt they will be. I have a brake pad change coming up in the next couple weeks .
maybe
eBay Motors: 99 00 01 02 03 04 Mustang Titanium Frt & Rr Brake Pads (item 190060841427 end time Dec-15-06 09:27:48 PST)
or would these work?
eBay Motors: 1999 Ford mustang brake pads (item 220059915015 end time Dec-18-06 01:00:00 PST)
(don't know if I included these)
eBay Motors: Bosch CERAMIC FRONT Brake Pads MUSTANG (item 180063706623 end time Dec-23-06 01:00:07 PST)
or lastly:
eBay Motors: HAWK HPS Front BRAKE PADS Ford Mustang GT, Thunderbird (item 170060330510 end time Dec-21-06 16:53:06 PST)
Old 12-14-2006, 12:36 PM   #2
bluemustang's Avatar
Re: brand of brake pads?
ive personally used the Hawks brand i like it but thats just me
Old 12-14-2006, 12:45 PM   #3
Region: Iowa
thanks. I just need to get an idea of what the hell is wrong, but I'm almost certain it's the pads. I'm hoping the caliper isn't failing. (only one wheel is acting up, and it has been for a little while)
Old 12-14-2006, 12:58 PM   #4
what symptoms do you have? How many miles on the car? I know a few people (myself included) whose calipers went around 60K miles.
-Denver
2002 Mineral Grey GT, 5-speed: MGW short throw, JLT CAI: SOLD
2002 Electric Green V6, Auto: SOLD
greenpony02 is offline   Reply With Quote
Old 12-14-2006, 01:41 PM   #5
I just replaced my front and rear rotors and pads two days ago. All I did was went up to Autozone and bought their cheapest pads (Duralast). They stop my car.
Old 12-14-2006, 02:01 PM   #6
Stumpy's Avatar
if one side is wearing faster than the other, your caliper is probably sticking. check you slide pin when you change your pads. it may be sticking. just shoot it with brake cleaner and walk away. after you put it back together though. hopefully that will do the trick. otherwise, replace your caliper. padwise, i have no idea.
~Roman~
2003 Mustang V6 Vert with a Flowmaster Super 40 series dual exhaust
I'm not a target in the sights of your mercy. I've never asked for anything. I'm not asking now.
Stumpy is offline   Reply With Quote
Old 12-14-2006, 05:41 PM   #7
rocknbronco's Avatar
I would say the Hawk pads
Mustang wanted for here...
rocknbronco is offline   Reply With Quote
Old 12-14-2006, 08:54 PM   #8
Region: Iowa
for symptoms... since I got the car (with around 70,000 miles on it) the passenger's front brake has produced A LOT of brake dust... easily 10 times what the other wheels did. My car now has 96,000 miles on it, and it sounds like the brake is staying down after I let off the brake... also, you can sort of hear it dragging as I'm driving ... but only very slightly. Am I going to have to replace the caliper also? What about the rotor?
Old 12-14-2006, 11:26 PM   #9
Does your steering wheel shake when you brake?
Old 12-15-2006, 12:17 AM   #10
I bought some Bendix pads from Advanced Auto, but haven't put them on yet.
JROC is offline   Reply With Quote
Old 12-15-2006, 07:30 AM   #11
Region: Iowa
no, the steering wheel doesn't shake... but that front side shakes just a little. More like the grinding causes it. So is the brake pad just dragging a little? I am scheduling myself some time to change the pads on the 27th. I'll flush the brake fluid at the same time... since I doubt it's been done yet.
Old 12-15-2006, 10:05 AM   #12
brake pads shouldn't "drag". It sounds like it may be the caliper. Does the car seem to pull when you brake?
-Denver
Old 12-15-2006, 10:35 AM   #13
Region: Iowa
no, the car doesn't pull.
Old 12-17-2006, 06:32 AM   #14
edross's Avatar
mine shakes when i brake, whats up with that
edross is offline   Reply With Quote
Old 12-17-2006, 07:36 AM   #15
Region: Iowa
I bought the ones for the 99 v-6 (didn't read first )... are those going to fit?
Old 12-17-2006, 11:23 AM   #16
Rotors need turned or replaced
Old 12-17-2006, 02:12 PM   #17
edross's Avatar
with 56,000 miles on the car do you think i can have them turned instead of replaced?
Old 12-17-2006, 02:16 PM   #18
More than likely.
Old 12-17-2006, 02:24 PM   #19
edross's Avatar
More than likely.
how much were the rotors and pads at autozone?
Old 12-17-2006, 02:25 PM   #20
Rotors were 25.99 and pads were around 27-28. I just got the cheapest they had.
Old 12-17-2006, 05:30 PM   #21
Turning rotors increases the chance of warping (makes them thinner). For the price of new rotors vs turning them, I think it's worth it to just replace them but that's JMO.
-Denver
Old 12-17-2006, 05:31 PM   #22
I agree.
Old 12-17-2006, 06:35 PM   #23
MonteCitan's Avatar
I'm using hawk HPS pads all around on the buick.. (and slotted rotors..) w/ braided lines to the front..
now stops hard enough that ABS kicks in over ~80% braking.. before it'd come to a stop more like... a truck
They're relatively clean, and though they grumble a bit more than stock, they don't squeal, so they're easy to live with
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 12-17-2006, 06:43 PM   #24
Region: Iowa
will the v-6 brake pads fit the front calipers on the GT? I'm winning the bid, and there's 7 hours left on it. Somehow, I think I'll end up getting them. I will also probably get the new rotors, cause O'Reilley's here is going to charge me $20 to turn each side of the rotor and the inside of the rotor is BADLY marked... so they may not want to turn it anyway, but it's also been turned a time or two before, as it's pretty thin. I was debating getting slotted and drilled rotors.
Old 12-17-2006, 06:44 PM   #25
I am not sure but I would think they would fit.
Old 12-17-2006, 06:58 PM   #26
bbunt302's Avatar
The GT and V6 from 99-04 both have the same PBR front calipers.
Scary stuff.
Old 12-17-2006, 10:19 PM   #27
Thomas91169's Avatar
i dunno, its 5$ each to return them at Pep Boys if you just bring them the rotor (IE not attached to a car). if i remember its 30$ each at your local auto store.
being able to turn the rotor depends on how much material is still left on the surface. once its down to a certain point, it is too far out of spec to be turned.
as for pads, i just get the ones that dont squeal (ceramic i believe) that cost like 60$ a pair at autozone. any other ones squeal after a month.
-Thomas-
Old 12-18-2006, 07:30 AM   #28
Region: Iowa
yeah, I got the ceramic ones... and this is what I'm thinking.
Since the rotor has already been turned possibly a couple times, and is getting decently thin. I will just have them turn the inside face, which is the one with the grooving... and I'll leave the other faces the way they are, since there is NO grooving at all on them. Then, I'll replace the pads, and see if I get the same intense build-up of brake dust on my rim on that side. If I do, I will take it as the brake caliper failing. So, to fix this, Cobra calipers and rotors on the front ... that would be around January... after I have about a month to evaluate whether the caliper is failing or not, and that's 3 pay checks away. I can do the whole brake swap for around $300... so that makes me happy. Does it sound like a plan that'll work?
Old 12-19-2006, 01:10 AM   #29
yeah
Old 12-20-2006, 08:29 AM   #30
all8280bcc's Avatar
Is it making a grinding noise or is more like a brushing noise. Cause mine has this light brushing sound coming from the front when i took it to my buddy at ford he said everything was normal. BTW you have 96k on an 02 damn i thought my 00 with 86k was alot.
00 Mustang GT: Upr x-pipe,Magnaflow Cat-back, MAC intake with 60mm mass air, underdrive pulleys, 3:73, and tuned
01 CBR RR: Full Erion exhaust, power commander, and intake
all8280bcc is offline   Reply With Quote
Old 12-20-2006, 10:52 AM   #31
Region: Iowa
lol, yeah, I had an 01 with around 90,000 miles... that I totalled almost a year ago, put 85,000 miles on it in around 2 years
Old 12-20-2006, 11:06 AM   #32
mileage really isnt a big deal. The 4.6L last a long time unless its abused (Look at how long they even last in taxis!). I have 88k on my 02 GT and 54k on my 03 Cobra (sold now), but then again i bought both of those from california commuters who drove them every day almost 2 hours.
-Thomas-
Brake Pads Mustangfan2003 1996-2004 Mustang GT 13 07-15-2008 05:13 PM
Best brake pads? MarkuzLS1 General Car Discussion 6 01-01-2008 08:28 AM
brake pads blumustang98 Pre-2005 V6 Mustang 12 06-11-2007 07:32 PM
brake pads charkelly9 Pre-2005 V6 Mustang 32 11-24-2005 10:59 AM
Brake pads 19ClearCobra96 1996-2004 Mustang GT 2 02-20-2005 04:26 PM
05:33 PM
