grinding noise from pass. front - Mustang Evolution
Old 12-16-2006, 11:04 PM   #1
jimmy_beaner's Avatar
Region: Iowa
ok, so yeah, checked the brake pad I could get to... and that pad is still 1/2 there or more so I doubt the problem is from that one... I'm fearing two things. The first is the smallest worry, and that's that the rotor on the inside is gonna be all sorts of ****ed up. This is because I'll just get some slotted and drilled rotors, and new pads, and see if the caliper caused the problem, or if it was just the inner pad that ****ed everything up.
The biggest worry is that a wheel bearing is going out. The grinding is getting worse. And it's not just when I'm braking now... it's bad when I start until I get to about 25 mph. It reminds me a little of when my dad's F-250's ball joints needed replacing, except that was only on some sorts of turns that it sounded awful.
Other than removing the wheel and having a look, is there any way to tell easily via some simple driving test which is the problem? (Also, my brake fluid is low, as the E-brake warning indicator comes on when I brake hard [if that helps diagnose a problem])
Would a sound clip help you guys? Seriously, I picked up the tripod from my house today, and have cable internet at my new apartment, so I can upload the video and you guys can get a better appreciation for everything. please help me... I'm tired of my car trying to die on me.
Old 12-16-2006, 11:46 PM   #2
Re: grinding noise from pass. front
Sounds like your inner brake pad is nothing but metal and its now grinding your rotor away every time you brake.
I'd recommend not driving it till you replace everything. The fronts don't take that long.
Old 12-17-2006, 08:35 AM   #3
Region: Iowa
that's the problem though... I don't have the choice of not driving it. I HAVE to drive from here to Iowa City (40 mins), and then I HAVE to drive BACK here to replace the rotor (most definitely) and the brake pads... as there are two mechanics that live here that I know (one is my gf's cousin).. and they're gonna help me with it.
Old 12-17-2006, 08:37 AM   #4
i had a creaking sound in my car on the passenger side and i only heard it when i took off, lifting the front of the car. i thought it was a bad spring but then i got a new, smaller gf and it doesnt do it anymore
Kyle is offline   Reply With Quote
Front end Noise ?????? ArmyStangGT 1996-2004 Mustang GT 7 02-09-2009 09:13 AM
Grinding Noise From Gears parkerr1 General Mustang Discussion 5 12-16-2008 06:34 PM
loud grinding noise! roach 1996-2004 Mustang GT 13 03-24-2008 11:01 AM
WTB pass side front seat belt assem. 01mineralgrey6 Mustang Parts for Sale and Wanted 0 04-08-2005 05:35 PM
grinding noise from diff. Horse Pre-2005 V6 Mustang 8 04-27-2004 05:47 PM
01:24 AM
