Solid Rear Suspension Setup - Mustang Evolution
Old 12-25-2006, 06:19 PM   #1
Thomas91169's Avatar
Ok you solid rear jockers. If i was to stay with solid rear for the sake most the IRS setups are on the east coast and they dont know what crating/FedEx Freight means, What would i need to get it up to the feel of IRS?
I want a setup that doesnt skip over bumps, squats when i hit it, is more suited for daily driving and twisties and less straight line. i want it to handle very well and be very stiff. Im not much of a suspension guy, which is why a direct IRS swap is easy to me and gets me where i want to feel without much suspension brainwork. I visited Maximum Motorsports but i was like a little kid in a candy store, lots of parts that i have no idea what they do. Keep in mind also, i do have side exit exhaust, which might be an issue.
Solid rear guys, this is your chance to show me, Pimp my Rear End!. Post up links to parts and a description of what they do and set up my rear end. oh and dont forget the rest of the car. its on c-springs now but i need some better shocks (possibly tokico 5way adjustables). keep in mind it CANNOT get any lower, i have enough trouble with the roush kit getting in and out of parking lots and jacking up the car.
btw this will not be another IRS vs SRA thread, it looks like IRS isnt gonna happen so i must work with what ive got.
btw i will be ordering 3.90 or 4.10 gears (whatever they have in stock) and the install kit from american muscle, and i will be taking the rear end off and having it rebuilt.
-Thomas-
Old 12-25-2006, 06:29 PM   #2
bbunt302's Avatar
Re: Solid Rear Suspension Setup
Road & Track Box, 2002-04 GT HT [RTB-8] - $2,382.54 : MaximumMotorsports.com Store, Buy Now!
or...
Maximum Grip Box, 1999-04 GT [GB-6] - $4,537.80 : MaximumMotorsports.com Store, Buy Now!
Just depends on how much you want to spend and how well you want it to handle.
Scary stuff.
Old 12-25-2006, 07:45 PM   #3
wow. looks like i have a bit more saving to do.
you think the subframes will have clearance issues with the side exhaust? ill prolly have to take it off and get it re-fabricated post-subframe install.
i think i might fore-go buying a bike come springtime and just buy my buddies next year.
-Thomas-
Old 12-25-2006, 08:37 PM   #4
Zim
You want to **** me?
Zim's Avatar
You cant get subframes with side exhaust.
I like toys
Old 12-25-2006, 08:39 PM   #5
bbunt302's Avatar
Yeah, I think you'll have to do without the subframes unfortunately... But at least you'll have plenty of clearance for a torque arm if you choose to go with the high-end package. Even if you do go with the Road & Track Box, I'd probably add a torque arm. They make a great deal of difference when combined with the panhard bar.
Scary stuff.
Old 12-25-2006, 08:55 PM   #6
Subframes make a big difference, I was wondering if they would clear with the side exhaust. So...do the roush convs not have subframes?
Old 12-25-2006, 09:13 PM   #7
Scut95's Avatar
If you get new shocks, don't get the tokico's. The rears are a pain in the *** to adjust because the adjuster is on the top of the shock which means you either have to take the trunk apart to adjust them or cut holes in the liner. KYB AGX shocks are really nice, cost about the same and have the adjuster knobs on the bottom of the shock in the rear so you can easily get at it. The fronts still have the same set up where you hafta stick the screw driver in the top to adjust but those are no problem to get at.
Old 12-25-2006, 09:32 PM   #8
^^^yeah it was like that on my eclipse too, the rear strut towers had a 3" clearence under the rear quarter panels. i set them at the recommended 4 before installing them, and set the fronts to 3.
does anyone have pics that show where the MM subframes attach and how they look under a car? or does Roush have a subframe connector specifically for the roush to clear the side exhaust?
btw what exactly do the panhard bar and torque arms do?
-Thomas-
Old 12-25-2006, 09:40 PM   #9
MarkuzLS1's Avatar
Send a message via AIM to MarkuzLS1
A panhard bar locates the rear end left-to-right under the car.
A torque arm controls the angle of the rear-end.
I like turtles.
MarkuzLS1 is offline   Reply With Quote
Old 12-25-2006, 09:50 PM   #10
MarkuzLS1's Avatar
This is a ****ty picture, and I apologize. I'm too lazy to continue searching for a better one...
I like turtles.
Old 12-25-2006, 10:05 PM   #11
hrm, i might go with these:
Rear Grip Package, 1999-04, HD, Standard
http://www.maximummotorsports.com/st... subframe con.
Adjustable Rear Swaybar, 7/8" x .120" wall, bolt-in kit
Chassis Brace Package, 1998-04 Mustang HT, GT
and then later on do MM springs and a strut/shock combo.
if i get the full length subframes in bare metal, can they be modified to clear side exhaust if need be, or will they basically lose their strength and become useless if touched?
btw marc that was a good find.
-Thomas-
Old 12-25-2006, 10:34 PM   #12
Zim
Zim's Avatar
Your exhaust pipes hang right where the SFC's need to go. You cant do subframes, dont waste your money... or do, then sell them to me at a cheaper price after you realize you cant install them.
I like toys
Old 12-25-2006, 10:59 PM   #13
You can get subframes connectors for a side exhaust but their not as cheap. I know Roush makes some, but I like the Hans Racecraft ones. Their $500 though.
Hans Racecraft - Ford Mustang Subframe Connectors
Mustang Subframe Connectors - Roush
JROC is offline   Reply With Quote
Old 12-26-2006, 12:04 AM   #14
zim, if i do decide to get the package i linked with the "Standard Length" ones, ill let you have them for cheap. i might just get the roush ones if the standard dont fit. remember, while i do have a side exhaust setup, its routed a wee bit differently than an actual roush. me and the guy at the exhaust shop tried to get the best possible fitment with the least amount of bends. unless the subframes connect to where the tips go, it might be different. im 95% sure zim is right and it wont fit, but who knows, 5% might be in my favor!
-Thomas-
Old 12-26-2006, 09:36 AM   #15
bbunt302's Avatar
When you do, I would seriously consider going with Bilsteins. I love them on my '90. There's no need for adjustability when the manufacturer gets the perfect combination of handling and comfort to begin with.
Also, on second thought you have to have subframes to use the torque arm. The torque arm actually bolts to the subframes. Hopefully you can still get away with the special side exhaust subframes, but you may want to give MM a call to be sure.
Scary stuff.
Old 12-26-2006, 03:10 PM   #16
yeah i was looking at the bilsteins too. I have 2300 in the bank now and i will probably wait till i have 3500 till i start ordering anything so i have room for the gears+install kit and however much its gonna cost to rebuild the rear end itself to rid myself of that godforsaken moan.
-Thomas-
Old 12-27-2006, 01:51 PM   #17
Region: Hawaii
Here is the Subframe connector for your setup. Full length with a X barace to tie the two together and a intergrated drive shaft loop. 275.00 weld on and clears side exit exhaust. It's the one that i will be getting
EvM Full Length "X" Brace Subframe Connectors - $275.00 : Evolution Motorsport, A Mustang Performance Company
99 Atlantic Blue V6- SOHC 4.6 swap, Tremec 3650, 8.8 rear end/ Flowtech Ceramic LT headers, off-road x-pipe, Spintech side exit exhaust. K&N drop in filter, removed snorkel, 18x10, 18x9, Anthracite Bullitt Replicas 295-35's, 265-35's. Eibach Pro-Kit springs, M&M Camber Plates
wrecked2001 is offline   Reply With Quote
Solid rear+wheelhop=wtf? 1996stang 1996-2004 Mustang GT 18 06-18-2007 05:47 AM
good rear suspension setup? notstock02gt 1979-1995 Mustang GT 6 05-01-2007 06:08 PM
Rear suspension suggestions MustangMatt Pre-2005 V6 Mustang 15 12-20-2004 03:05 PM
best suspension setup for drag BrooksPS Pre-2005 V6 Mustang 2 03-11-2004 09:09 PM
really wierd, good, situation... solid rear ---> IRS tire The Bar 15 08-05-2003 05:42 AM
07:28 PM
