2000 mustang GT tapping sound in engine - Mustang Evolution
Old 12-31-2006, 01:54 PM   #1
dreamcar00's Avatar
Angry 2000 mustang GT tapping sound in engine
3043.1
Hello,
My name is Joseph Kent Iím from Huntsville Alabama. I own a 2000 model mustang GT with a 4.6 SOHC completely stock. The engine has a ďtickĒ (is the best way I can describe it ) at high RPMís anything over 2500 itís almost like a knock but not quite as loud. It doesnít do it in idle only going down the road just before you change gear. Just cruising down the road in fourth or fifth gear you canít hear it. Due to only being able to hear it going down the road, I canít pinpoint where this tick is coming from, itís pretty loud you can even hear it inside the car. Do you have any suggestions as to what it might be? Does the 4.6ís have any kind of issue with valve springs breaking? Or could it possibly be something on the front of the engine timing chain etc? The car has not lost any power or oil pressure. It also doesnít do it when the engine is cold, only after it heats up. It seems like when the engine reaches temp it starts to make this ďtickĒ. Any help or suggestions would be greatly appreciated.
Thank you very much.
Joseph Kent,
dreamcar00 is offline   Reply With Quote
Old 12-31-2006, 01:56 PM   #2
Re: 2000 mustang GT tapping sound in engine
Can you hear it if you rev the engine up at a stop?
Old 01-07-2007, 05:00 AM   #3
Send a message via AIM to Invictus Send a message via Yahoo to Invictus
Sounds like possibly an exhaust leak... Do you change your oil faithfully? If the engine is stock then I doubt it's any valve/piston clearance issues so you can rule that out. Get a friend to stuff some towels in your exhaust pipes and rev up a bit, if the noise gets worse then you've successfully diagnosed your problem. Exhaust leak.. If you're driving and and you upshift unnecessarily to bring your car into low RPMs and give it some gas... (say 40MPH and in 5th gear) you should really be able to hear it. If all else fails bring it to the stealership.
Invictus is offline   Reply With Quote
Old 01-07-2007, 08:37 AM   #4
MonteCitan's Avatar
how loud/audible is it? as previously asked, can you hear it if you rev it up in neutral?
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 01-07-2007, 08:47 AM   #5
dreamcar00's Avatar
the sound is pretty loud i can hear it inside the car as i'm going down the road. And you can't hear it in idle but me and a friend got out there the other day and i was just patting the gas sitting still in the driveway, and as you pat the gas up to around 2200 rpms you could hear the sound. it sounds like it might be coming from the front timming chain cover area.still not sure what it is,but i don't think it is an exauhst leak.
Old 01-18-2007, 03:29 PM   #6
USMCSS's Avatar
Back when I had a 92 GT I had a noise similar to what you are describing. I was told exhaust leak but couldn't find one. I had not too long before that installed roller rockers. Well, me and a buddy took it all apart again cause that's where the sound seemed to come from. We found that one of the rods and slipped out of the pre-made hole on the rocker arm and had made a smaller indintion on the arm that kept the rod in place. The ticking came from the rod pushing the rocker arm up to high and it was hitting the cover that covers the rods and rockers (going blank on the name right now cause I'm dead tired) which is what the "ticking" was from.
Saleen #232
USMCSS is offline   Reply With Quote
Old 01-18-2007, 03:40 PM   #7
bullitt482's Avatar
TALK ABOUT LUCKY!!!!!!
I think you are trying to say valve cover
01 Bullitt
Old 01-18-2007, 05:14 PM   #8
USMCSS's Avatar
Yes valve cover. Right as I posted the reply it came to me. Me a ****** sometimes...
Saleen #232
Old 01-19-2007, 04:58 PM   #9
bullitt482's Avatar
That's ok, when we had the bullitt, my wife would always correct me when I said "cam covers." She was raised pushrod. Now I have seen the light
01 Bullitt
2000 mustang
2000 Mustang GT - Intermittent Driver Side Sound 3ricchu Mustang Audio & Video 1 07-07-2010 10:06 AM
squeaking sound from engine midnightrider_s Pre-2005 V6 Mustang 5 10-12-2009 07:39 AM
2000 Ford Mustang Replace Radio No sound from speakers tralfaz Mustang Audio & Video 0 06-26-2009 03:24 PM
HELP-Thudding sound - engine: Manfold? chris7869 Pre-2005 V6 Mustang 7 08-22-2007 06:44 PM
01:44 AM
