2000 4.6 RPMS die when started after rain - Mustang Evolution
Old 07-19-2010, 08:45 AM   #1
I have a 2000 4.6 MT with 80000 . When I go and start my car after a rain storm or heavy fog it wont idle correctly until it is completely warmed up. When it is about half way warmed up it will idle iradictly from 300-1000 RPMS. The car has a BBK intake and FM cat backs. Would this be a IAC valve or something? Any Ideas would be greatly appreciated.
Thanks
maboater86 is offline   Reply With Quote
Old 07-19-2010, 08:50 AM   #2
jimmy_beaner's Avatar
Region: Iowa
Re: 2000 4.6 RPMS die when started after rain
You might check the spark plugs to make sure they're dry. My GT had an issue similar to this and found out water was getting in there.
Old 07-19-2010, 09:00 AM   #3
Tape's Avatar
I would clean the maf and the IAC before I did anything else.
Tape is offline   Reply With Quote
Old 07-19-2010, 01:36 PM   #4
i changed the plugs about 4000 miles ago and it didnt change anything, but i will check everything. thanks for you help, i will report back if there is further issues.
tires for lower rpms? jgordon Mustang Wheels & Tires 8 01-03-2010 04:14 PM
sputtering at low rpms eddie1 1996-2004 Mustang GT 28 05-12-2009 08:22 PM
If you die in the game.. you die in real life! wiarumas The Bar 2 06-08-2006 05:45 AM
engine's rpms go up and down while driving mike the spike 1979-1995 Mustang GT 6 12-21-2005 08:31 PM
Finding your speed from your rpms gdcpony Pre-2005 V6 Mustang 0 08-17-2003 01:17 PM
06:44 PM
