Help with spark timing - Mustang Evolution
Old 07-19-2010, 03:09 PM   #1
Hopefully somebody can answer this. I have a 99 GT complete bolt ons pulleys, cai, t/b, plenum, 3.73 gears and also have a stage II head work done. I have the computer programmed with the SCT 93 octane tune. Im thinking of playing with the spark timing a little bit more. How many degrees do you think I could add into the spark timing (over the added spark from the SCT tune) without hurting the motor? Or should I just keep going a degree at a time until I start to hear a little spark knock? Thanks guys Jimmy
Rawdawg440 is offline   Reply With Quote
Old 07-20-2010, 07:35 AM   #2
Re: Help with spark timing
you cant always hear detonation, install cheap copper plugs and set a timing, drive it, and inspect the plugs for poping spots etc (signs of detonation) as well as listen for it.
I would recommend letting someone tune the car vs trial/error as the end result will be better and safer.
Old 07-20-2010, 12:06 PM   #3
91sleeper's Avatar
The risk isnt worth the reward.
331stroked vortech 16psi
91sleeper is offline   Reply With Quote
3.8 timing marks. Foxone Pre-2005 V6 Mustang 0 05-26-2010 06:43 PM
Timing is off!!!! ballajb 1979-1995 Mustang GT 2 10-28-2009 02:09 PM
TIMING HELP!?!? timeformiller44 1996-2004 Mustang GT 2 04-27-2009 10:05 AM
Q about setting timing Z-EATER General Car Discussion 1 04-04-2008 08:03 AM
Timing question damighty5.0 1979-1995 Mustang GT 12 05-22-2006 04:23 PM
» Members Mustangs
Chome
GTGirl
LOU'CY
boink
Add your Mustang
10:40 AM
