Window Control Panel in Door - Dropping/Moving - Mustang Evolution
Old 07-22-2010, 11:48 AM   #1
SarasotaTim's Avatar
Talking Window Control Panel in Door - Dropping/Moving
Hi guys -
Having a problem with my driver's side door in my 2004 V6 'Stang...the actual control panel in the door appears to be falling/sliding down, and has (over the last couple of months) slid almost completely down...taking off the panel it's apparent is isn't attached now to the plastic panel in any way, I see clips but not sure how it goes back, anyone ever had to reattach these before or had a similar issue?
Thanks in advance!
T
SarasotaTim is offline   Reply With Quote
Old 07-22-2010, 11:51 AM   #2
jimmy_beaner's Avatar
Region: Iowa
Re: Window Control Panel in Door - Dropping/Moving
a picture might help with your description. I had to replace the window regulator and motor in the GT.
Old 07-22-2010, 11:55 AM   #3
Sorry, yep I should have thought of that...will take one this evening and post it up.
Old 07-23-2010, 06:12 AM   #4
Here are a couple of images of the switch in its current state:
image on Flickr - Photo Sharing!
Old 07-23-2010, 07:06 AM   #5
Region: Iowa
gotcha... it screws into the door bezel. The screws have pretty aggressive threads as well (not fine ones like you'd find for metal). If you can't find the screws, check in the door for them or just go pick some more up. Make sure you don't get them too long as they'll easily puncture the door bezel.
Old 07-23-2010, 07:30 AM   #6
Awesome, I'll get on that tonight! Well, not tonight, we've got TS Bonnie moving in, but this weekend at some point lol Thanks man!
Old 07-23-2010, 07:49 AM   #7
Region: Iowa
not a problem... you may want to check the back of the bezel to make sure it isn't stripped out. If it is, you'll need a new bezel, some over sized screws or something in the bezel to assist
Anyone know how to remove a door panel? 00stang3.8 Pre-2005 V6 Mustang 15 04-04-2007 09:22 PM
Door Panel Problems Justin 1979-1995 Mustang GT 8 10-11-2006 01:51 PM
door panel insert idea Bane- Pictures and Videos 4 05-27-2005 12:19 PM
09:30 PM
