Would this pressure sender work as a replacement? - Mustang Evolution
Old 07-22-2010, 07:41 PM   #1
I hate how the OEM oil pressure gauge doesn't move with rpm like a high quality gauge would. If I remove the stock pressure sender from where the oil filter is and replaced it with this item from auto meter would it make the gauge move up and down with pressure?
THis is a sender for a short sweep gauge, which is basically what our stock gauge is.
Auto Meter
Just cant see the plug so not sure how I will wire it. Maybe the harness is a standard size?
ajpturbo is offline   Reply With Quote
Old 07-23-2010, 12:10 AM   #2
MonteCitan's Avatar
Re: Would this pressure sender work as a replacement?
It would not, our gauges aren't linked DIRECTLY to the sender, and are buffered.. The signal they get is averaged out, that way it doesn't drop or rise the way the oil pressure actually does (keeps people out of the service garage for unnecessary warranty claims)
If you saw your gauge fluctuate from the bottom to the top of the range without going out of limits.. frequently and often (and you were an average driver used to a typical one-spot gauge) you'd be worried, right?
In other words, to my knowledge (I've been wrong before) a different pressure sender will not make the gauge read differently
A pressure sender + aftermarket gauge WILL read differently
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 07-23-2010, 07:05 PM   #3
^ It's not that I doubt you but can anyone else confirm this?
So you're saying the return voltage from the sender goes to the ECU?
I just figured since the stock sensor is like 8 bucks that it's just an on/off or pressure/no pressure.
A better sender varies the amount of signal based on pressure, correct?
NO OIL PRESSURE bmxrr1990 Pre-2005 V6 Mustang 11 11-23-2009 10:04 PM
no fuel pressure ? Chasity 2005-2010 Mustang GT 12 06-30-2009 06:42 AM
Tire Pressure? runvsofthisbull Mustang Wheels & Tires 9 02-01-2008 12:02 PM
oil pressure help jesse4887 1979-1995 Mustang GT 25 06-01-2007 10:39 AM
Extra oil pressure sender unit for press gauge wesoakes Pre-2005 V6 Mustang 10 11-19-2006 12:57 PM
06:46 PM
