Is there a proportioning valve for the brakes? - Mustang Evolution
Old 07-24-2010, 06:46 PM   #1
2 questions.
Is there a proportioning valve? My mustang seems to nose dive when I brake which tells me the front brake bias is heavy. I have just installed eibach prokit springs and sways and it didn't help much.
I have a 5 speed and I can power block it so easy I'm surprised, which also tells me there is a heavy front brake bias. My 350Z couldn't do that and it had 50 more horsepower.
#2 do I have to romove the master cylinder to bench bleed it or can I crack the bleeders on the master cylinder and bleed normally? There are 2 bleed screws on the master cylinder.
Thanks in advance
ajpturbo is offline   Reply With Quote
Old 07-24-2010, 11:22 PM   #2
91sleeper's Avatar
Re: Is there a proportioning valve for the brakes?
350z had trac control didnt it?
331stroked vortech 16psi
91sleeper is offline   Reply With Quote
Old 07-25-2010, 05:32 AM   #3
^ I could turn it off just like on my mustang. But the 350Z did have EBD electronic brake force distribution which varied the amount of brake bias between wheels.
Old 07-25-2010, 10:01 AM   #4
91sleeper's Avatar
I am pretty sure that you aren't going to have that on your mustang
Old 07-25-2010, 04:27 PM   #5
I know I don't have EBD on the mustang. But is there a proportioning valve? Just curious why the mustang nose dives so bad and if I need to remove the master cylinder to bench bleed it or can I do it while keeping it on?
Old 07-25-2010, 05:17 PM   #6
DarkShadows's Avatar
Mustang naturally has strong front and weak rears.
March 2010 Mustangevolution Mustang of the Month 1st eva biatch!
DarkShadows is offline   Reply With Quote
Old 07-25-2010, 05:39 PM   #7
Ok, so is there a way to adjust that?
I see a little gold block that the brake lines go into about 6 inches away from the master cylinder, is that the proportioning valve? And is it adjustable?
Old 07-25-2010, 06:21 PM   #8
Not adjustable to my knowledge.
Old 07-26-2010, 07:49 PM   #9
Tape's Avatar
no proportioning valve no you don't have to remove the MC to bleed it.
Tape is offline   Reply With Quote
Old 07-27-2010, 08:35 PM   #10
Wow that's gay...the car dives so hard and I have new eibach springs.
Wonder what the little gold block is then below the master cylinder that the brake lines go into then?
I bled the master cylinder and to my surprise there was quite a bit of air in it but the brakes feel the same.
Old 07-28-2010, 01:48 AM   #11
Tape's Avatar
without seeing it I would guess part of the ABS.
Old 07-28-2010, 07:51 PM   #12
No electronics or wires go into it though. It's right against the driver side fender just below the master cylinder.
Old 07-28-2010, 08:43 PM   #13
hottcobra's Avatar
yes the car has a porp. valve. it is in the location your talking about. it is pre set from the factory and is not adjustable.
the master can be bleed on the car, but you will need to bleed the entire system also.
the bias is heavy to the front because the car is very light in the rear. If you lessen the bias to the front the back brakes will lock in the rear causing the to slide.
Old 07-28-2010, 09:05 PM   #14
So I've bled the MC. You're saying I need to bleed everything else again?
Just a small tweak would be good I think. I know you don't want it too strong rear.
Old 07-28-2010, 09:24 PM   #15
Tape's Avatar
a 99-04 mustang does not have a brake Proportioning Valve, maybe a 05+ does.
valve seals cms Pre-2005 V6 Mustang 2 08-21-2009 02:06 PM
Bypass valve & Blowoff valve sporter 2005-2010 Mustang GT 7 05-27-2007 02:57 PM
valve cover? Fishers Stang Pre-2005 V6 Mustang 4 04-17-2006 07:44 PM
Blow off valve drwang Pre-2005 V6 Mustang 32 10-13-2005 05:35 AM
new valve cover in Thomas91169 Pictures and Videos 9 04-03-2005 05:12 PM
12:04 AM
