injectors - Mustang Evolution
Old 01-24-2007, 02:07 PM   #1
Send a message via MSN to wht2002gt
injectors
hey guys I have mods on the motors and im looking to get some injectors.
is it worth the money, what size, and what brand. Should I buy from jegs or
is there a cheaper place that you recomend
not sure can't remember
wht2002gt is offline   Reply With Quote
Old 01-24-2007, 04:27 PM   #2
Kiljosh's Avatar
Re: injectors
In order to really tell you the size you should get or if you even need them, we're gonna need some more info.
What mods do you have done to your gt?
Old 01-24-2007, 04:47 PM   #3
Re: injectors
I can't tell you everything right now but I will try.
accufab intake and plenum / cold-air induction / long tubeheaders / chamber mid (H-Pipe) / magnaflow mufflers and tail pipes / plasma ignition booster / underdrive pully set / i think thats it I can't remeber and this weekend tihnking about getting a predator programmer ( if you think its worth)
and depending on taxes p.i. heads
Old 01-24-2007, 04:58 PM   #4
all8280bcc's Avatar
Re: injectors
if you get head go with a set of like 24lb but you wont REALLY need them but hey every bit counts and i highly suggest the tuner just got mine for xmas and i love it.
00 Mustang GT: Upr x-pipe,Magnaflow Cat-back, MAC intake with 60mm mass air, underdrive pulleys, 3:73, and tuned
01 CBR RR: Full Erion exhaust, power commander, and intake
all8280bcc is offline   Reply With Quote
Old 01-24-2007, 05:03 PM   #5
Re: injectors
When I get the tunner any suggestions on how to tune or is it explained in the manual
Old 01-24-2007, 05:07 PM   #6
Kiljosh's Avatar
Re: injectors
Depending who you get it from, im pretty sure that theyll include a tune on the programmer for your car. I would go with one of them if you have never used a programmer before.
Old 01-24-2007, 05:26 PM   #7
bullitt482's Avatar
Re: injectors
I don't think you'd need them unless you had either a power adder(nitrous, turbo, sc) or a set of aftermarket or port and polished heads with a different cam.
01 Bullitt
Old 01-24-2007, 05:50 PM   #8
Thomas91169's Avatar
Re: injectors
exactly.
unless you have a power adder or lots of naturally aspirated goodness, the stock injectors can keep up just fine.
the only time you need to upgrade injectors is when your duty cycles are close to or over 100% duty cycle. youre not even close with minor bolt ons, and even with VT stage 2 cams and heads, youll prolly be fine with a nice dynotune.
-Thomas-
Old 01-24-2007, 08:13 PM   #9
Re: injectors
so another words i should save the money i was going to use for the injectors and buy the p.i. heads from jegs. and do you know what size cam them have
Old 01-24-2007, 10:58 PM   #10
Re: injectors
PI Heads have PI Cams if thats what youre referring to. cam specs are those from a 99-04 GT, exact duration and lift escapes me at this time.
-Thomas-
Old 01-25-2007, 08:33 AM   #11
Herbstang's Avatar
Re: injectors
Go with a SCT Chip Support the site sponsors VMP Tuning - SCT Custom Ford and GM Tuning, Dyno-tuning Mobile Dynojet 224xLC, Mail order tunes, Flashers, Chips?
Old 01-25-2007, 07:58 PM   #12
Re: injectors
without any peripherals to read whats going on, you really are limited to what you can "Tune" with a handheld. you need other devices to tell you what the car is doing, where its doing at, and then use that information to make changes.
If youre ballsy like i am, you can just start leaning out the fuel and adding timing till you get predetonation (usually heard by a pinging) and then you have found the "Edge" of the tune, and then add some more fuel and take a degree or two out of timing to keep it on the safe side. but you have to know exactly what youre feeling and listening for. Ive tuned my own DSM and many other buddies with DSMlink, i have learned to tune by "Feel" and use the information provided on my readout as a backup, most times during a 3rd gear run i can feel when timing is pulled due to knock, or where i can add timing, or when there is too much fuel (the exhaust tone goes from very smooth to choppy or defined). then again, ive been doing this for years, i can have my buddy start the run, close my eyes as hes running up through 3rd, feel the different sensations, and when i open the laptop i already know what the graph is probably going to look like and where i need to make changes for the next run.
-Thomas-
Old 02-03-2007, 09:40 PM   #13
Re: injectors
hey if u have an 2002 u already have PI heads, if u r injector caps r a pinkish color then there 22lbs
02vert is offline   Reply With Quote
Old 02-11-2007, 03:22 PM   #14
Send a message via AIM to 96gt226410
Re: injectors
As far as aftermarket injectors, I have only used Ford Racing 24 lbs. I've used 2 sets of them and they've always lasted until I got rid of my car and worked great.
*FRPP headers, BBK O/R H-Hipe, Flowmaster Exaust, K&N FIPK, Mac 70mm TB, Steeda Tri-Ax, King Cobra Clutch-200 RWHP-Wahoo
*PI Swap, Headers, and Gears coming soon
96gt226410 is offline   Reply With Quote
Old 02-28-2007, 10:51 PM   #15
1234's Avatar
Re: injectors
Not sure on the power output but it will work you might need minor tuning to get the full power out of it
Old 03-07-2007, 05:03 AM   #16
Re: injectors
Hello, new to site. I posted an intro in the intro section.
As far as injectors, You really don't need them with just bolt ons. Just get a good tune. If you plan on going FI in the future injectors are a must. I would wait until then if you plan on it. They usually come in a s/c kit.
DSG 2004 Mustang GT, ProCharger P1SC intercooled 8psi, AFM powerpipe, Pro Products 75mm T/B & Plenum, SCT Big Air 2400 90mm MAF, 60# injectors, NGK plugs, SVT Focus fuel pump, B&M sport shifter, VRS O/R X-pipe, Flowmaster 40 Series cat-back.
2004forcefedGT is offline   Reply With Quote
14# injectors rydog Mustang Parts for Sale and Wanted 7 05-07-2008 05:20 PM
Injectors BigL34461 Pre-2005 V6 Mustang 2 11-10-2007 12:20 PM
#24 or #30 injectors? USMCSS 1996-2004 Mustang GT 2 06-11-2007 08:04 PM
Injectors jeffb_211 Pre-2005 V6 Mustang 14 05-09-2006 04:47 PM
19# injectors...$1 Junior2561 Mustang Parts for Sale and Wanted 0 11-07-2004 06:19 AM
10:05 AM
