01 Bullit intake - Mustang Evolution
Old 01-31-2007, 11:30 PM   #1
01 Bullit intake
I found a good deal on a slightly used 01 Bullit intake, it only has 24,000 miles on it. Will it fit my car and is it worth it? I have a 99 Gt 4.6l 2V.
bosscityboy86 is offline   Reply With Quote
Old 02-01-2007, 07:24 AM   #2
Re: 01 Bullit intake
If 5 peak hp and a bit better mid range is worth it to you, you should see a tenth of a second (about what an exhaust or cai does) in improvment. I am not sure how regular upgraded upper intakes are for the 2V in terms of boost but probably about the same.
Old 02-01-2007, 07:26 AM   #3
Send a message via MSN to 1996stang Send a message via Yahoo to 1996stang
It will fit your car but in my opinion its pointless those intakes cost anywhere from $600-$800 so if 5hp is worth that much to you do it.
2004 mach 1 stock and staying that way.
1996stang is offline   Reply With Quote
Old 02-01-2007, 07:45 AM   #4
all8280bcc's Avatar
yea but if he does further modifications it would def be worth the investment.
What are your future/current mods this will help make opinions a little easier
00 Mustang GT: Upr x-pipe,Magnaflow Cat-back, MAC intake with 60mm mass air, underdrive pulleys, 3:73, and tuned
01 CBR RR: Full Erion exhaust, power commander, and intake
all8280bcc is offline   Reply With Quote
Old 02-01-2007, 01:54 PM   #5
The parts that I have laying around to be put on are Patriot Performance Stage 2 heads, with Comp extreme energy stage 2 cams with beehive ovate valve springs. Slp loudmouthI catback, hooker longtubes, Offroad x-pipe, haven't had time or money to get these parts installed.But I do have a T-56 6speed, aluminum driveshaft, moser axles, 4.10 gears, and fenderwell cai and 70mm throttle body. I put all that in the first 3 weeks of owning it. I'm wanting to stay N/A.
Old 02-01-2007, 03:25 PM   #6
If you have all that to install go for it
Old 02-01-2007, 03:28 PM   #7
bullitt482's Avatar
Agreed, if he goes with FI or nitrous, it would be a great bit of insurance to go with that intake. Nitrous backfires/high pressures make 96-04 stock manifold GT crawl into the corner and bury their face.
01 Bullitt
Old 02-02-2007, 01:47 PM   #8
all8280bcc's Avatar
I would def put the intake on it especially if you are gonna go n/a. With the heads and cams the intake is a very good idea. I may suggest even goin with a typhoon intake. Those are great for n/a and FI/Nitrous applications if you want to add later
Old 02-03-2007, 02:52 AM   #9
I don't know about the typhoon intake, becuase i've heard that u might lose power with one. I'm might just wait until trick flow comes out with thier intake. I'm wanting to say it's gonna be around march or april when it comes out.
Bullit Prices PureVenom General Mustang Discussion 20 01-31-2008 03:23 AM
Bullit Intake - Schooling Needed bluemustang 1996-2004 Mustang GT 4 02-13-2004 06:28 PM
Bullit Wheels cypress The Bar 3 12-21-2003 06:36 PM
12:59 AM
