Having second thoughts on Long Tubes - Mustang Evolution
Old 02-09-2007, 11:38 AM   #1
USMCSS's Avatar
I haven't gotten my x-pipes or headers done yet and I'm having second thoughts on doing the long tubes. My car is a supercharged Saleen and is already lowered with the Racecraft suspension. It already scrapes every speed bump and I know that'll be even worse with long tube headers on there. I am doing the off road x-pipes but I was wondering just how much HP gain I'd really get with doing the long tubes as well. Are they really worth the money or should I look at investing that money into something that would get me better gains??? Bigger bang for the buck, etc...
Saleen #232
USMCSS is offline   Reply With Quote
Old 02-09-2007, 12:07 PM   #2
Herbstang's Avatar
Re: Having second thoughts on Long Tubes
I'd say about 15 to 20 Want more gains get the S/C ported Stiegemeier Supercharger Porting and Repair Service
Old 02-09-2007, 12:49 PM   #3
USMCSS's Avatar
15 to 20 HP just from LT headers alone? I really didn't think they gave that much extra HP. BTW, taking my S/C off and sending it to Missouri is not an option...
Saleen #232
Old 02-09-2007, 01:23 PM   #4
Herbstang's Avatar
Got that # from doing a little research here's what header did for a GT and you got a S/C maybe look at some shorties http://www.jbaheaders.com/images/dyno/05mustangdyno.jpg
Old 02-09-2007, 01:24 PM   #5
Assuming this is a positive displacement saleen SC...gains will be in the 5-10 hp range since a PD blower can only push X amount of air whether their are headers or not.
The most you will gain from headers is a slightly cooler charge temp (this is where the HP gain comes from), slightly lower PSI of boost, and the ability to bump the timing a little to pick up some more HP.
You will probably scrape more with the long tubes as well. My long tubes go in next week some time...I am not lowered, and I have a feeling I will be scraping based on some other cars I have seen.
And, Steig won't gain you much with the saleen SC (or whipple/KB for future reference). It is already pretty efficient and porting may lower your power just like KB says about porting theirs.
Old 02-09-2007, 01:33 PM   #6
Herbstang's Avatar
The Master has spoken :worship:
Old 02-09-2007, 01:35 PM   #7
USMCSS's Avatar
So you are more or less saying that it's really not worth the money and I really am risking having a car that scrapes BAD? What is something else that would be more worth my doe to add on? I'm already having a new chip put in, having it dyno'd and changing to a 4:10 rear end
Saleen #232
Old 02-09-2007, 01:36 PM   #8
I was expected to see 40ish hp from long tubes as well...then I read an awesome article that explained why that isn't the case. Great read: Effectiveness of Engine VE Changes with a Positive-Displacement Supercharger - ModularFords.com
Old 02-09-2007, 01:41 PM   #9
Originally Posted by USMCSS View Post
So you are more or less saying that it's really not worth the money an I really am risking having a car that scrapes BAD? What is something else that would be more worth my doe to add on?
Long tubes let you turn the boost up a little more and/or run a little more timing and still remain on pump gas. You can max out a setup, then add long tubes and gain more room for more boost and timing without buying stock in Torco.
If you are already scraping with your suspension, it may just mean you will scrape in a few more parking lots.
If you don't already have one, get a custom dyno tune. A 2006 Saleen S-281E came to the shop and only put down 468 at the wheels. The shop car, with the same boost levels...same SC...puts down 520. Granted, the shop car has long tubes and o/r x where as the saleen has stock manifolds and h pipe. The major difference is that the shop car is running ~21* of timing, the saleen is running 14*. The long tubes allowed for the timing to be bumped up much higher = more hp.
So, if you ask me...get the long tubes. You will just need to be careful as you probably already are. Then, once they are installed, get on a dyno and get a custom tune. I will see where you are located once I post this...if it is in one of a couple states, I can give you a definite "go to" list of tuners for this. :beer:
Old 02-09-2007, 01:47 PM   #10
USMCSS's Avatar
Now I'm really baffled and undecided. Ya it scrapes but I am already VERY careful when it comes to parking lots. I already have a guy near by that is supposed to be the best around for Dyno. Jeff Harris owner of ProSpeed Performance in Powder Springs, GA. He quoted me $499 for chip plus Dyno. That's for an s/c car
Saleen #232
Old 02-09-2007, 01:52 PM   #11
That is about right. Here it is $399 for the tuner and then $150 an hour for dyno tuning....unless you bring your own tuner then it is $425 an hour for tuning.
Honestly, IMO, get the long tubes...and get the tune. I would say get a tuner though and not a chip, but I couldn't tell you why one is better than the other really. I just like the idea of being able to datalog with the SCT tuner anytime I want...
Old 02-09-2007, 02:02 PM   #12
USMCSS's Avatar
SOOO...with all that being said. O/R X-pipes plus LT headers plus chip and dyno, what kind of HP gain can I expect to see?
Saleen #232
Old 02-09-2007, 02:09 PM   #13
If you do it all...with the bump in timing...20-40 at the wheels...I know, kind of wide range, but all cars are different and some respond better than others...and some people tune better than others.
Besides, the sound difference will be very much worth it.
Long Tubes and K-member runvsofthisbull Pre-2005 V6 Mustang 7 10-29-2008 06:19 AM
*gauging interest* mac long tubes and catted h pipe... dark Mustang Parts for Sale and Wanted 7 06-12-2006 09:44 AM
long tubes kraz3y Pre-2005 V6 Mustang 14 03-02-2006 04:43 AM
v6 long tubes and h pipe joebadguy Mustang Parts for Sale and Wanted 10 10-26-2004 09:45 PM
long tubes? timpryor Pre-2005 V6 Mustang 18 07-04-2004 06:59 PM
11:02 AM
