Under drive pulleys, should I or shouldn't I? - Mustang Evolution
Old 02-20-2007, 03:29 PM   #1
I have an 03 GT with 4.6, off road x pipe, flow master 40's, 3.73 gear, mhw shifter, bbk cold air kit,
I have been thinking about getting under drive pulleys before I have the dyno tune done. I drive the car on the street and on long trips from time to time. I live in the middle of Florida.
I have had two speed shops tell me not to get them.
What do you people think?
Thanks in Advance
microflight is offline   Reply With Quote
Old 02-20-2007, 03:35 PM   #2
Justin's Avatar
Send a message via AIM to Justin Send a message via Yahoo to Justin
Re: Under drive pulleys, should I or shouldn't I?
Do you have alot of accsessories... System or anything that would use more battery than normal?
http://www.mustangevolution.com/forum/signatureuploads/sigpic5474_2.gif
(Project "TORQUE"):burnout:
Mods - Off Road H w/ Flowmaster 40s and 3" x 22" Tips, Shiftkit, Shorties, and 4.10s
Soon to come - UDPs, Off Road X-Pipe, A/T Cooler, and 03' Cobra Rims
Club - Tha Crew Leader of Muscle Car Division
Justin is offline   Reply With Quote
Old 02-20-2007, 04:27 PM   #3
bullitt482's Avatar
What he said. We have pullies, but don't have a kickin stereo, and also spends a lot of time at higher rpm since it's highway all the way to work. If you are in stop in go alot, charging the battery might be a problem.
01 Bullitt
Old 02-20-2007, 04:38 PM   #4
I never had any issues with a crank only under drive (25%) dont expect much from them as with any bolt on but ... they do help gas milage a tad.
Old 02-21-2007, 01:51 PM   #5
bluemustang's Avatar
I dont know why everyone says they effect the battery and charging cause i had a UDP on my old V6 ontop of a system that was pushing 2 1000.1 amps to my subs and never once did it make a differ.
On an older car it does but not on newer cars.
I say go for it I noticed a differ when i put mine on not much but just enough
Old 02-28-2007, 11:00 PM   #6
1234's Avatar
I to have had no problems and i have a system but the only thing it helps is the car revs and drops revs a bit quicker as long as you get the lightwieght underdrive crank pulley. Gas mileage does increase a bit
Old 02-28-2007, 11:15 PM   #7
maximus's Avatar
^ how do you have a profile for your stang but dont have any pictures in it?? come on man. lol. i went to a shop once and asked about a whole bunch of performance mods when i was still learnin what to/not to do with the 6er. the shop owner/top mechanic said that he always told ppl to stay away from them and he also said that if a car came in with ud pulleys, he would take them off of the persons car and put stocks back on. how gay is that. im like yea and you wanna do work on my car. lol. so, i have always been told not to put ud pulleys on cuz the gains arent worth the possible negatives. just thought id share.
maximus is offline   Reply With Quote
Old 02-28-2007, 11:19 PM   #8
1234's Avatar
i just joined the site havent loaded any yet and ive heard nothing but good ive never heard anything bad about them
Old 02-28-2007, 11:22 PM   #9
Send a message via MSN to 1996stang Send a message via Yahoo to 1996stang
I've heard alot of bad about them but i dont have any issues same battery has been on my car since i bought it over a year ago.
1996stang is offline   Reply With Quote
Old 02-28-2007, 11:23 PM   #10
1234's Avatar
What have you heard
Old 02-28-2007, 11:26 PM   #11
They cause over heating issues,charging issues etc. i dont care what people say my car is living proof its BS for the simple fact i beat the living **** out of the motor and i have yet too have it overheat or a dead battery.
Old 02-28-2007, 11:30 PM   #12
1234's Avatar
Same here not a problem
Old 03-01-2007, 02:13 PM   #13
all8280bcc's Avatar
No problems here and ive had mine for about 6 months now and i have a system
00 Mustang GT: Upr x-pipe,Magnaflow Cat-back, MAC intake with 60mm mass air, underdrive pulleys, 3:73, and tuned
01 CBR RR: Full Erion exhaust, power commander, and intake
all8280bcc is offline   Reply With Quote
Old 03-01-2007, 02:57 PM   #14
Thomas91169's Avatar
I have the march piggybacks and never any issues. Theyre what, 150$, theyre a pita to install, and they give you zero sotp gains. so yeah, if they werent such a pain id uninstall them and sell them off, but im lazy so ill just leave them on for now. but yeah, in retrospect, i wouldnt do them again if i ever got another car.
-Thomas-
Old 03-08-2007, 05:23 AM   #15
USMCSS's Avatar
OK, I've heard pros and cons with most of your guys' stangs but what about with mine. I have a Saleen supercharger and no system. What it be worth my money to get them?
Saleen #232
USMCSS is offline   Reply With Quote
Old 03-08-2007, 09:27 AM   #16
i personally thought it was worth it. I noticed a difference when I put them in
Old 03-09-2007, 11:00 AM   #17
crazeflier07's Avatar
Send a message via AIM to crazeflier07
I had the crank UDP and the alternator pulley as well when I had the air ride on. I had issues with that because the compressor would draw off the battery and with the smaller pulley for the alternator the charging system wasnt able to keep up so I did have to replace my battery later. I took them off when I took off the air ride but I put the crank UDP on only again. Acceleration is a tad bit quicker as well as the RPMs and I was able to rev higher between shifts. I havent had any problems with just the UDP so I think its worth it.
~Jon~
Sinister Six
1998 3.8L V6
Done So Far:
~CAI, True dual exhaust, UDPs, MGW Shifter, H&R springs, Stage 1 & 2 supension kit, performance rotors & pads, steel braided lines, 1 inch rear spacers, A.R. Rebel 17x9s with BFG rubber! :thumbs2:
crazeflier07 is offline   Reply With Quote
Old 03-09-2007, 11:52 AM   #18
Herbstang's Avatar
Same Here
Old 03-09-2007, 02:07 PM   #19
bbunt302's Avatar
I'd say buy a crank pulley and leave it at that. I started out with an entire set, but eventually took off the alternator and water pump pulleys due to various issues.
The crank pulley is definitely worth it though in my opinion. Pretty cheap for the gains.
Scary stuff.
Old 03-09-2007, 02:15 PM   #20
No, do not get them. If you were N/A like most of the people here, I would say definitely get them. Being blown, do not get them. While they may work out just fine, there is no sense in slowing down your water pump and risking any heat related issues. The gains are not worth the risk in my opinion.
Old 03-09-2007, 09:01 PM   #21
Ha, rob, you beat me to it.
DO NOT put a udp on a supercharged car, you are just risking messing up more stuff. Also, if it slows down your accessories...wouldn't it slow down the supercharger too? Food for thought.
Old 03-09-2007, 09:18 PM   #22
Only if the crank pulley was on the same belt. For example, on my car, I could put an UD crank on...and it not slow the SC down because the crank and the SC are on seperate belt systems. Only the alt is on the SC belt.
But ya....no udp for a blown car. 3-5 hp isnt worth the risk.
Old 03-09-2007, 09:54 PM   #23
USMCSS's Avatar
I looked into it and found that I can put a pulley on the SC itself and get at least 30-50 hp gain. Heard the same thing from 3 different performance shops. They all recommend that I DO NOT get the UDP's on the rest because I might actually lose power. Smaller pulley on the SC would mean more boost. Exactly what I'm looking for. Of course I need a good dyno tune and all but I'll be having all that done all at once when I get the off-road x-pipes and LT headers and 4:10 rear end.
Saleen #232
Old 03-09-2007, 09:58 PM   #24
Long tubes will not boost your HP much (5-10 maybe, got an article you can read to find out why) but it will let you run an even smaller pulley and still stay on pump gas and that is how you gain HP.
As for the other part about they told you a smaller pulley...yes, get a smaller pulley. It is the same type of SC as the 03/04 cobras run...their first todo is always a pulley...pulley = power.
But, if you go too small and run too much boost...your internals will go boom unless you have them forged up.
Old 03-10-2007, 08:44 AM   #25
USMCSS's Avatar
I've been hesitant towards the LT headers due to my car being lowered. So in your opinion Pure Venom. what would YOU run header wise. I keep getting too many conflicting stories and I want to try to add them all up and then average them out if you know what I mean.
Saleen #232
Old 03-10-2007, 08:54 AM   #26
MonteCitan's Avatar
I put an overdrive pulley on the regal.. I noticed one heck of a difference
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 03-10-2007, 12:05 PM   #27
Headers are a good idea, but I would save them till later because the power gains are not going to be what is expected when compared to a NA car. They will, however, lower your boost levels while maintaining your power level and allow you to run more spark to increase the HP output.
As far as headers go though, I would recommend the stainless works long tubes. They look great in person and have a great sound.
To gain power, I would suggest running a smaller pulley on the SC, making sure you have good cooling in place like a good radiator and a good heat exchanger...then I would save the headers until you get everything set because they will be a big chunk of change.
Old 03-10-2007, 03:10 PM   #28
USMCSS's Avatar
Well I know that it would be easier to intall the headers while installing the x-pipes so they can go ahead and have the x-pipes cut to proper length. Like a one shot deal
Saleen #232
Old 03-10-2007, 06:55 PM   #29
Actually, if you go with stainless works or kooks, just order their X pipes with the headers.
Old 03-10-2007, 08:33 PM   #30
USMCSS's Avatar
I'm actually having a performance shop do them for me. They're fabricating the x-pipes themselves. Plus, it's the only place around that'll do the off roads for me around here
Saleen #232
Old 03-19-2007, 02:05 PM   #31
I've had lots of problems with underdrives in the past, including on a 97 Cobra, but I grudgingly installed them on my 02 GT and have had zero charging or cooling issues. I usually just put the crank and water pump pullies on, and leave the alternator alone. Get a set with an SFI balancer, and it is a worthwhile upgrade. Power was up on the dyno per expectations - something like 8 HP if I remember right.
-Matthew
90 LX Coupe
02 GT Convertible
03 F-250 PSD
06 SRT8 Magnum
http://www.tecmotion.ca
Matthew is offline   Reply With Quote
Old 03-22-2007, 07:56 PM   #32
silverstangboy's Avatar
whoa, ACTUAL DATA!!!!!! something im not used to on this site
93 mustang notch
~450hp 331 stroker - Sold
Old 07-30-2007, 12:31 AM   #33
i could see how it would cause cooling and charging problems, cuz the alternator and water pump are spinning slower. but i have never actually seen it cause any problems... but i guess it could.
2003gt is offline   Reply With Quote
Under drive pulleys question mk70ss 2005-2010 Mustang GT 1 07-30-2010 10:14 PM
Just installed my under drive pulleys! SickGT 2005-2010 Mustang GT 8 07-07-2010 10:08 AM
Pulleys! gasteven Pre-2005 V6 Mustang 16 04-15-2010 11:25 AM
Under Drive Pulleys 2007STANG Pre-2005 V6 Mustang 2 06-01-2009 10:09 AM
Pulleys SaturnMan8227 Pre-2005 V6 Mustang 12 01-19-2009 02:18 PM
03:07 PM
