Help Me. Dome Light Acting Up - Mustang Evolution
Old 08-22-2010, 05:30 PM   #1
brentmustanggt's Avatar
hey yall .....new guy here !!!!!!!!!!!! what if your light wont come on when you open door or try to turn on with headlight switch ....... but i can turn it on manually by reaching up and flipping the switch on ??? what the heck is going on here ???????????
brentmustanggt is offline   Reply With Quote
Old 08-22-2010, 05:36 PM   #2
help dome acting up
Old 08-22-2010, 06:31 PM   #3
Zebs5408's Avatar
Re: Help me . dome acting up
check your fuses
04' mustang 3.9 40th Anniversary Edition- (V2 Vortech Supercharger, 38# injectors, 3.73 gears w/ T-lok, Predator Diablo, Mac cold air intake, Port & polished upper AND lower intake manifold, Mac Long Tube Headers, Mac o/r H pipe, flowmasters, 2.5 flowmaster tips)
03' Mustang GT (20" Cobra R's, 40 series Flowmasters)
Zebs5408 is offline   Reply With Quote
Old 08-22-2010, 10:11 PM   #4
Cool Re: Help me . dome acting up
Originally Posted by Zebs5408 View Post
check your fuses
I went by a diagram for a 03 even though mine is a 02 ! They were fine , gonna check them ALL in morn and will post what I find!
Old 08-22-2010, 10:56 PM   #5
MonteCitan's Avatar
Does it come on if you open the passenger side door?
I haven't looked at a wiring diagram on this so I can't tell you entirely for sure where to look, just throwing out some thoughts on where I would start with diagnosing a car for this issue..
The circuit itself for power to the dome light is ok as you can turn it on manually with the switch.. In turn, got to be a concern (open/short grounding issue in the door switch/headlight switch circuits) Again just off the top of my head, no guarantees .. I'd lean towards the headlight switch being the central link..
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 08-23-2010, 12:00 AM   #6
just went out 2 double check and NO lite when i open the passenger door. ive read someting about an acutator in the door causing some issues with a lite staying on (F150) . I hope i dont have to tear my damn door panel off as ive yet to accuire many tools. Hope its a looose wire behind my headlite switch .....ill pop it off in the morn and let yall know what if ANYTHING I FIND OUT !!!!! THANKS AGAIN YALL
Old 08-23-2010, 08:04 PM   #7
MonteCitan's Avatar
If it does NOT come on with either door nor the headlight switch, it is not an actuator, if light stays on it is likely a switch, if it doesn't come on with any of them then it's not.
It's either the switch or a circuit problem.. If I could find my EWD I would tell you exactly where to look... It's in my toolbox somewhere.. I'll try and get down there soon
Old 08-23-2010, 09:52 PM   #8
Oh wow that wud be great !
Old 08-26-2010, 11:31 PM   #9
OsirisGuy's Avatar
Re: Help Me. Dome Light Acting Up
Are you sure the bulb isn't out?
The dome light (connected to the door switch and headlight switch) is different from the Driver and Passenger map lights.
OsirisGuy is correct
OsirisGuy is right
2002 Mustang GT
Old 08-27-2010, 07:34 AM   #10
95YellowGT_5.0's Avatar
Send a message via AIM to 95YellowGT_5.0
i agree, mine is the same way, the witches on the lamp are for the MAP lights, the dome light is seperate. the bulb could just be out
1995 Mustang GT, 5.0 302 Cubic Inch, K&N filter, Short Throw Shifter, Off Road X-Pipe, Flowmaster American Thunder cat-back, MSD Cap and Rotor Kit, MSD Coil & Wires
95YellowGT_5.0 is offline   Reply With Quote
Old 08-27-2010, 07:51 AM   #11
ummm ok now im confused i only have ONE lite in my car its in the middle of the headliner with a switch on either side. (gimmie a break my first stang as ima bowtie Z28 guy converted over) rear view mirror has no lites at all on them if that helps any . what is a courtesy lite and what is map lite .
Just bought a Haynes manual .....imma get to digging in there....but someone feel free to break it down to me ....!!!!!
Old 08-27-2010, 08:23 AM   #12
OsirisGuy's Avatar
All SN95 ('94-'04) Mustang coupes have three bulbs in the center headliner. The three bulbs are located in one plastic housing. The three bulbs are Driver Map, Dome Light, and Passenger Map. The Map lights are connected to the switches attached to the housing. The Dome light is connected to the door switches and headlight switch.
Basically the lights that come on with the door and the lights connected to the dome light switch are separate from each other physically. Physically meaning that they are individual entities (bulbs) but I believe are still on the same fuse (Fuse 7, 15 Amp [2003 Ford Mustang Workshop Manual]). If it was a bad fuse or other electrical problem more than likely none of these lights should work.
To replace the bulb (or see what I am talking about) use a small flat head screwdriver, or preferably a pick tool and pop open the clear plastic casing. You should see a small rectangular discoloration on the clear piece on where to insert the pick tool.
As for the differences in Map Vs. Dome, there really isn't much. I don't know if there is an industry or company standard but as far as I can tell the dome light is so because it is a general overhead light providing luminescence to the whole interior. The map lights are more focused to light up a specific rider's area (such as for map viewing).
OsirisGuy is right
2002 Mustang GT
Old 08-27-2010, 08:32 AM   #13
SaleenFiend's Avatar
Verbatim
Old 08-27-2010, 06:54 PM   #14
Old 08-28-2010, 12:56 AM   #15
ok thank yall. opened it up and the center bulb was missing . went to napa and got one. well it was missing cause now it wont cut off !! wow the issue of now tracking down why it wont cut off . ive read something somewhere on here about "that" issue . anyways i think its the door actuator thing ?!
Old 08-28-2010, 11:08 AM   #16
OsirisGuy's Avatar
First check and make sure the headlight knob is not turned all the way up. If you pull it out, so as your headlights are on, and then you turn the knob to control the cluster dimmer, it will reach a certain brightness until it stops and one more turn until it clicks. That click is to turn on the dome light manually. IN short, make sure the knob isn't turned ALL the way up.
Other than that make sure all your latches are latching properly. That is make sure the driver and passenger doors are shutting correctly as well as the trunk is shut completely.
OsirisGuy is right
2002 Mustang GT
Old 08-30-2010, 11:05 AM   #17
Dome light staying on is a common problem, the 'switch' for the dome light is located on the latch of each door. It is most likly the drivers side door since it gets used more often than the passenger door. The switch is located in the door latch mechanism and it gets full of crud over the years and sticks causing the dome light to stay on.
Not a hard fix, remove door panel, remove latch mechanism and replace switch, make sure you get the correct switch for the door you are working on, they are different from the drivers to passenger door.
2001 GT AUTO, MAgnaflow Cat back, 70mm TB, K&N FIPK, C-springs, 275/40/17 all around
jjandascog is offline   Reply With Quote
Old 08-31-2010, 10:57 PM   #18
Yes I figured it be the bulb first. Than if it isn't must be worst off.
tjzola is offline   Reply With Quote
Dome light fuse Renegade 800 Pre-2005 V6 Mustang 7 09-06-2016 07:45 PM
Acting weird in neutral 4.10GT 1996-2004 Mustang GT 0 09-07-2008 08:51 PM
My PC is acting dumb Seph The Bar 6 02-05-2006 08:24 AM
dome lights 95 DrOpToP Pre-2005 V6 Mustang 1 05-28-2005 07:40 PM
Adding LEDs to the dome light. Dom Mustang Audio & Video 14 03-08-2004 09:00 PM
04:32 AM
