My Headers - Mustang Evolution
Old 02-27-2007, 12:25 PM   #1
ridenmystang's Avatar
My Headers
K so my headers sounded aweful come to find out the bolts came loose. Apparently this is what will happen all the time Im told. So I'll have to check them about every month and tighten them. So I got them retightend. I bought the copper gaskets becuase I heard they were the best ones and wont blow off as easy. It still sounds like its leaking. Someone said that headers heat up alot and will kind of make the copper melt so that it forms a better seal around the header so it wont leak but that it takes a month or two. Another guy that worked at heads and headers said he doesnt use gaskets he grinds them flat and never has a problem with them leaking. Any suggestions ????????
One wicked 03 GT FOBRA
ridenmystang is offline   Reply With Quote
Old 02-27-2007, 12:29 PM   #2
MarkuzLS1's Avatar
Send a message via AIM to MarkuzLS1
Re: My Headers
Having to retighten headers a few times is normal. Usually only takes a time or two to get them good.
I like turtles.
MarkuzLS1 is offline   Reply With Quote
Old 02-27-2007, 12:30 PM   #3
MarkuzLS1's Avatar
Re: My Headers
Percy's ''Dead Soft'' Header Gaskets - JEGS
I used those header gaskets on my old Camaro, and they did a good job.
I like turtles.
Old 02-27-2007, 03:39 PM   #4
bullitt482's Avatar
Re: My Headers
There is also a kit where you can get "locking" header bolts to where they won't slip loose over time. They're like 45 bucks or so through summit, worth it IMO.
01 Bullitt
Old 02-27-2007, 05:03 PM   #5
MonteCitan's Avatar
Re: My Headers
I have those through summit, never had a problem with bolts coming loose
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 02-27-2007, 05:07 PM   #6
Re: My Headers
So are they real hard to take off if I ever decided to?
Old 02-27-2007, 05:13 PM   #7
MonteCitan's Avatar
Re: My Headers
on the 5.0 they're just bolts that come with clips that rest against the tubes of the headers, that keep the bolts (with slots for the clips) from turning past a certain point, they're cake to put on and cake to remove
Old 02-27-2007, 05:28 PM   #8
Re: My Headers
well once they are tightened a couple times they should stay right?? or is this something I need to invest in?
Old 02-27-2007, 05:30 PM   #9
MonteCitan's Avatar
Re: My Headers
When I put shorties on my '02 I torqued them to spec and never had another issue -> my 5.0 the headers came loose twice, lost two bolts entirely before I got the summit bolts; haven't had a problem since
Old 02-27-2007, 10:20 PM   #10
Kiljosh's Avatar
Re: My Headers
I used loc-tite red on my header bolts, haven't had a problem with those that go into the heads. the collector bolts on the other hand, those I have lost a few times just going down the road and all the sudden massive exhaust leak.
Old 02-28-2007, 01:01 AM   #11
Region: Hawaii
Re: My Headers
If they came with lock washers try to put a hardened washer between the lock washer and the header flange. Also what you can do, and this is from my Aircraft experience. you will need bolts with Safety wire holes in the head, and what you can do is safety wire the two opposing bolts around the heads so that when one loosens it tightens the other one. I am going to try this with my headers depending on how much room i got. You don't need alot of room to do it. Here is a pic of three bolts in-line. Notice how if one loosens it tightens the other and vice-versa.
99 Atlantic Blue V6- SOHC 4.6 swap, Tremec 3650, 8.8 rear end/ Flowtech Ceramic LT headers, off-road x-pipe, Spintech side exit exhaust. K&N drop in filter, removed snorkel, 18x10, 18x9, Anthracite Bullitt Replicas 295-35's, 265-35's. Eibach Pro-Kit springs, M&M Camber Plates
wrecked2001 is offline   Reply With Quote
Old 02-28-2007, 04:36 PM   #12
bullitt482's Avatar
Re: My Headers
I WOULD NEVER USE LOCTITE ON HEADER BOLTS. This can eventually cause the header bolt to stick inside the head permanently and then you'd have to remove the heads to drill out the bolt, retap the hole and hope that you didn't tap the hole wrong(awaiting jokes) and cause misalignment with the hole on the header. I would never recommend using any sort of loctite on any part that involves the engine/heads/intake/etc.
01 Bullitt
Old 02-28-2007, 09:45 PM   #13
Kiljosh's Avatar
Re: My Headers
I have been able to remove them twice already without any difficulty...
Old 02-28-2007, 10:41 PM   #14
1234's Avatar
Re: My Headers
Ive never had problems with the bolts coming out. I always tightened them as tigh as i could get them on the flanges, on the heads just torque them to spec
headers SaturnMan8227 Pre-2005 V6 Mustang 8 01-20-2009 07:13 PM
help with headers COmustang 1996-2004 Mustang GT 1 05-18-2008 05:58 AM
LT Headers machoman013 Pre-2005 V6 Mustang 4 04-13-2006 09:35 PM
Headers for '98 FloMasta24 Pre-2005 V6 Mustang 1 08-14-2004 01:07 PM
10:08 AM
