Tranny Swap - Mustang Evolution
Old 02-28-2007, 07:39 PM   #1
1234's Avatar
Tranny Swap
Does anybody know if a t5 trans will fit in an 03 gt that came with a tr3650?
What trans will fit?
Old 03-01-2007, 03:58 PM   #2
bullitt482's Avatar
Re: Tranny Swap
Why would you want to go with a weaker tranny, unless it's built?????
I'd say with the correct bellhousing and/or DS it should work, but I'm no expert.
01 Bullitt
Old 03-01-2007, 04:27 PM   #3
Thomas91169's Avatar
Re: Tranny Swap
yeah, umm, a 3650 is better anyways.
and yeah, i think the bellhousing is the same, might be a little different, but youll know once you get them side by side. driveshaft is prolly the same.
did you blow up your 3650?
-Thomas-
Old 03-01-2007, 05:28 PM   #4
Re: Tranny Swap
it wont work, the T5 bolts to the bellhousing from the outside (much better idea... so you can drop the trans without the bellhousing...) and its overall different... im sure you COULD make it work but it would cost more than getting the right one.
Old 03-01-2007, 09:13 PM   #5
1234's Avatar
Re: Tranny Swap
yes i blew up the old one, it no longer has second gear thanks for the advice.
Old 03-01-2007, 09:27 PM   #6
MonteCitan's Avatar
Re: Tranny Swap
driveshaft is different, # of splies or something along those lines, I don't have the exact specs
theoretically you could get a bell housing that will bolt up to the 4.6 & the t5 but I don't know of any companies that make them
even if you blew up 3rd gear, 3650 is a better trans...
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 03-01-2007, 09:44 PM   #7
Send a message via MSN to 1996stang Send a message via Yahoo to 1996stang
Re: Tranny Swap
he didnt blow up third it was second
1996stang is offline   Reply With Quote
Old 03-02-2007, 08:37 AM   #8
MonteCitan's Avatar
Re: Tranny Swap
my apologies... I was thinking third because that's the gear I've destroyed... in more than one t5
Old 03-02-2007, 11:37 AM   #9
Re: Tranny Swap
third is what went in my t45 guess its just a gear that gets abused the most.
Old 03-02-2007, 05:04 PM   #10
1234's Avatar
Re: Tranny Swap
does anybody know where to get internal tranny parts for a tr3650. like the syncro blocking rings, besides the dealer?
Old 03-02-2007, 05:05 PM   #11
Re: Tranny Swap
Call holcomb motorsports and ask for michael he can help you
Old 03-02-2007, 05:06 PM   #12
1234's Avatar
Re: Tranny Swap
Thanks for the help
Old 03-07-2007, 12:29 AM   #13
1234's Avatar
Re: Tranny Swap
So i got a t45 out of a 98 cobra and a tranny out of a 96 gt which 1 should i go with? both work perfectly fine and i dont know what the tranny code on the 96 gt is. if anybody could help?
Old 03-07-2007, 05:17 AM   #14
Re: Tranny Swap
The bell housing is different (bolts up different) and the input shaft has a different spline count. How about a TKO 500? Or a T56?
DSG 2004 Mustang GT, ProCharger P1SC intercooled 8psi, AFM powerpipe, Pro Products 75mm T/B & Plenum, SCT Big Air 2400 90mm MAF, 60# injectors, NGK plugs, SVT Focus fuel pump, B&M sport shifter, VRS O/R X-pipe, Flowmaster 40 Series cat-back.
2004forcefedGT is offline   Reply With Quote
Old 03-07-2007, 11:00 AM   #15
Re: Tranny Swap
the 96 gt is a t-45 just as the 98 cobra is im unsure of any differences.You can use that tranny we have done it before but you have to make a trans mount the t-45 is either shorter than the 3650 or longer i can't remember.
Old 03-07-2007, 12:05 PM   #16
1234's Avatar
Re: Tranny Swap
They are both the same size and all the monuts line up the speed sensor is the only difference i have found. Im trying to put it in today. I cant find a conversion kit to make the cable driven speedo an electric speedo.
Old 03-07-2007, 12:08 PM   #17
Re: Tranny Swap
If i can get ahold of my tuner he is in daytona for bike week right now.I will find out for you.I dont remember running into that problem but its been almost 4 years since we did it.
Old 03-07-2007, 12:30 PM   #18
1234's Avatar
Re: Tranny Swap
Cool Thank You
Old 03-07-2007, 02:15 PM   #19
Re: Tranny Swap
Cool Thank You
You need too call dallas mustangs they make a kit to adapt the mechanical gear too electric
Old 03-07-2007, 06:10 PM   #20
1234's Avatar
Re: Tranny Swap
Dude you rock i owe ya 1
Old 03-07-2007, 08:12 PM   #21
Re: Tranny Swap
no problem man all i did was make a phone call
03' motor and tranny swap with 98' GT PLEASE HELP!!! BAttitude7689 1996-2004 Mustang GT 10 01-20-2010 06:33 PM
c4 tranny ryanxstang Pre-2005 V6 Mustang 11 08-20-2008 04:53 PM
98 mustang engin/tranny swap Mustangbobby General Mustang Discussion 0 04-17-2008 07:34 PM
98 Engine/tranny swap Mustangbobby Pre-2005 V6 Mustang 0 04-17-2008 06:51 PM
New Tranny! Dan Pre-2005 V6 Mustang 3 03-04-2004 07:15 PM
» Members Mustangs
Pwny
BaSohol
BLkvibe
Blkvibe
Add your Mustang
12:31 PM
