Tit problem on front brakes. I'm stuck - Mustang Evolution
Old 08-27-2010, 10:08 AM   #1
Just had a bit of a rough time putting on my hawk pads from american muscle. Brakes are pretty straight forward and I've done them plenty but I need to take these back off to get piece of mind.
One side the caliper went on fine but the other side had 2 little tits on the backing plates of the pads that prevented the caliper from slinding on. I ground one of them off. All the pads are the same style, I called hawk.
But now the other side, I'm afraid I got it on luckily and the caliper may have slid over the tit and will put uneven tension on the pad. Those tits look like they slide in a groove on the caliper fingers opposite the pistons. The tits were off a little on the one side thats why I had to grind it off.
So I don't know how I got the first side to go on thats why I have to take it back off but really don't want to.
Thanks for the help.
ajpturbo is offline   Reply With Quote
Old 08-27-2010, 12:32 PM   #2
RHuckster's Avatar
Re: Tit problem on front brakes. I'm stuck
I just did my fronts & backs with new rotorpro rotors & hawk ceramics & I know the rear caliper pistons have to be just right to line up with the tits on the pads but I don't remember needing to worry about it on the fronts. I don't think there where tits on the front pads, only the backs. My front & rear pads where different.
Rick
2007 Mustang GT,Tint,C&L,XCal 2,Mac,Hood Pins,Smoked Fogs,Air Brushed Pony,Clear Front Corners,Blackout Panel,Black Trim Rings,Black Gas Door,Black Faux Cap,Black Shelby Style Spoiler,Black Side Window Louvers,Deep Dish Black Bullets, Nitto 555's(285/40/18 & 255/45/18)
RHuckster is offline   Reply With Quote
Old 09-21-2010, 05:28 PM   #3
did you get it fixed yet. the back pad should have the tit& the outer should have none. old ford
old ford is offline   Reply With Quote
Old 09-21-2010, 09:07 PM   #4
racefan966's Avatar
Region: Idaho
As Old Ford said. Did you get it staightened out?
racefan966 is offline   Reply With Quote
Old 09-22-2010, 12:04 AM   #5
HE HE you all said "TiT"
Straublittleman is offline   Reply With Quote
Old 09-22-2010, 01:57 AM   #6
Tape's Avatar
lets see if "BOOBIES" will excite you
Tape is offline   Reply With Quote
Old 09-22-2010, 03:23 AM   #7
He He BOOBIES!!! (o)(o)
Old 09-22-2010, 03:44 AM   #8
Tape's Avatar
lol
Old 09-22-2010, 10:55 AM   #9
I have tit problems too.
Old 09-22-2010, 11:14 AM   #10
SaleenFiend's Avatar
Too small or too large (although quite impossible while speaking visibly... i guess I only meant in a BS back hurting kind of way)?
Old 09-22-2010, 11:17 AM   #11
Pretty much "I got 'em and they get in the way" kind of way?
Old 09-22-2010, 11:38 AM   #12
I'm sure most people don't mind them in their way.
Old 09-22-2010, 12:24 PM   #13
... I guess I will not talk about tits
since its just a single piston caliper it might cause an issue, heck even sticking. I would personally take them back off and ensure its all done right. Send pics to hawk before to many miles and who knows they may give you a set of free ones to replace them with aka put up and use later.
Old 09-22-2010, 02:13 PM   #14
No tits for you?
BTW I'm sure the little tits on the pads won't hurt much other than a little bit of the alignment on the rotor. I would just make sure your wearing correctly on the pad/rotor with no grooves, noise, or excess wear/dust.
Old 09-22-2010, 08:26 PM   #15
Don't believe you send pics J/K
BRAKES front & rear chris7869 Pre-2005 V6 Mustang 1 09-08-2007 07:16 PM
front brakes 96bluegt 1996-2004 Mustang GT 2 05-21-2007 08:20 PM
Rear Brakes (for a 95) problem 95stang_man Pre-2005 V6 Mustang 9 02-02-2005 07:04 PM
OK... HUGE problem. I have no brakes! Zim Pre-2005 V6 Mustang 9 10-29-2003 05:33 PM
05:59 AM
