I'm missin'.....Plug problems? - Mustang Evolution
Old 03-10-2007, 09:14 PM   #1
ChickStang02's Avatar
Send a message via Yahoo to ChickStang02
ok, so, my car has a mis in it, so, I change the plugs this morning. I remove the boot, and it's full of sand. I'm assuming because I just bought it from MI. and everythings sand up there. BUT there's one spark plug that I can't seem to get out. And it's the most corosive and has hardened sand around it, so I'm assuming the last person to change them, didn't change that one either, because it's a ***** to get out. Dunno. I'm hoping the new plugs will make her run better, but I can't seem to get the last one out, any idea's?
Jayme
ChickStang02 is offline   Reply With Quote
Old 03-10-2007, 10:00 PM   #2
meteorachick's Avatar
Re: I'm missin'.....Plug problems?
holy crap, i live next to the beach and i don't have a bit of sand in my car lol
Modified 2004 V6
Old 03-10-2007, 10:09 PM   #3
Thomas91169's Avatar
im guessing its the passenger side closest to the firewall.
a couple wobble head extensions should be able to get you the right amount of leverage and work better at delivering the maximum amount of torque to the nut than a universal.
-Thomas-
Old 03-11-2007, 11:27 PM   #4
1234's Avatar
Put the tool on and put some force behind it. It will break loose.
Old 03-12-2007, 08:05 PM   #5
rocknbronco's Avatar
Get some good penitration oil once the car is warmed up spray some heavy coats on there and maybe even a light coat or two before it gets hot should let it sit over night and then try it the next day if at all possible if not wait thirty minutes and try again.....
rocknbronco is offline   Reply With Quote
Old 03-12-2007, 08:10 PM   #6
definatly put some penetration oil on it, breaking bolts is not fun.
Old 03-12-2007, 08:13 PM   #7
Kiljosh's Avatar
Yea like he said, I would get the motor a little warm, not operating temperature, spray some pb blaster on it, use the right tools to get enough leverage and it will pop loose. The easiest way to move a stuck bolt is instead of putting a constant force on the ratchet, set it on the plug and kind of hit it quickly. Like a quick push, stop, quick push, stop. Just make sure its on there nice and tight and keep doing quick pushes.
Old 03-12-2007, 08:15 PM   #8
bbunt302's Avatar
Also remember: Longer handle on wrench = more torque.
Put a piece of pipe on the end of the wrench and then give it a shot.
Scary stuff.
Old 03-12-2007, 08:23 PM   #9
Yeah a cheater pipe might be needed but dont brake the plug.
Old 03-12-2007, 10:21 PM   #10
Ok guys, did almost everything you all suggested, and after a couple hit and misses, I GOT IT! Thanx for the help, I also changed my air filter, OMG if i don't think it was the original. It was so flippin' black, I don't know how the car was breathing at all! I've never seen anything like it. Bad news, It's still missin' any suggestions what should come next? Coils maybe?
Jayme
Old 03-12-2007, 11:04 PM   #11
check the fuel filter. if that fails, seafoam it.
-Thomas-
Old 03-13-2007, 07:48 AM   #12
make sure you dont over tighten the plugs and you use antiseeze! (youve got it all back together now... but just fyi)
Old 03-13-2007, 04:43 PM   #13
silverstangboy's Avatar
blow the plug holes out really good with compressed air, I had a lil bit of moisture in one of mine that I had no idea was there, was enough to arch the load to the block instead of through the plug though.
93 mustang notch
~450hp 331 stroker - Sold
Old 03-13-2007, 10:36 PM   #14
Hmm...never thought of that silver. I think maybe I'll try a new gas filter next. It's just pretty depressing to just get my car, pay a good chunk for it, and have to work on it right away. The mis seams to get worse, instead of better.
Jayme
Old 03-14-2007, 06:26 AM   #15
bbunt302's Avatar
I'm going to put my money on the coil pack again. They seem to be a pretty common problem on the 99-04 3.8s. Have the local dealer check it out.
Scary stuff.
Old 03-14-2007, 10:15 AM   #16
Send a message via MSN to 1996stang Send a message via Yahoo to 1996stang
this car is a gt or atleast the one in the garage is.
1996stang is offline   Reply With Quote
Old 03-14-2007, 10:27 AM   #17
bbunt302's Avatar
And this is in the 4.6 Mustang GT section. You know... you may be on to something...
It still sounds a lot like the coil packs though.
Scary stuff.
Old 03-14-2007, 10:31 AM   #18
could very well be and i just happen to have a whole set for-sale
Old 03-14-2007, 11:22 AM   #19
Kiljosh's Avatar
I know it seems bad that you have to do all this work to the car just to get something like this to stop but just imagine when the car is actually running great. Like bbunt said the coil pack is definitley up next, I would put my internet cash down on it as well.
Old 03-14-2007, 08:21 PM   #20
Yea, It seems that's what it probably is, the hubby says we'll buy one and keep changing it to see which one it is. HAHA 3.8 pfft 4.6 power! haha. I'll let ya know what happens next, hopefully it will fix her.
Jayme
Old 03-14-2007, 08:25 PM   #21
Just a heads up coils are $55+ each at a dealer if you need a set and are for sure thats the problem let me know i got a whole set for less than half a dealer will charge.
Old 03-14-2007, 10:33 PM   #22
oh, I thought we were talking 4-6 not 3.8, in that case disregard my previous post
(hosed again by bbunt I see, so it is in fact a 4.6, whats with that?)
93 mustang notch
Old 03-15-2007, 10:24 PM   #23
LOL, not sure where the confusion there is, but she is indeed a GT 4.6 . So what I did is buy one coil, and I'm changing it until I find out where it needs to be, is this smart, or should I change them all together, I thought I was just saving myself some money. But now I'm not too sure.
Jayme
Old 03-16-2007, 03:45 PM   #24
bullitt482's Avatar
Changing them one at a time is no big deal. Only thing that would suck is if you have more than one coil pack bad. I would take it to a dealer(or a trusted someone with a scanner), hook it up to a scanner, see which cylinder is misfiring and change that coil pack.
01 Bullitt
Old 03-16-2007, 11:12 PM   #25
yeah, good advise bullit
this is what I did when I had a good friend working for ford... cost nothing, found no problems with my equipment, did however locate the plugs giving me problems and led to me finding my moisture problem.
93 mustang notch
Old 03-16-2007, 11:20 PM   #26
But thats where my problem lies. My brother is a ford mechanic, he hooked it up, telling me all the while that most time, unless the check engine light is on, it won't show anything wrong. And sure enough, it wouldn't show anything. So at the moment I'm going through them, one per day, so I can drive it a while on each change over. And nothing so far. Hope soon I'll have some good news to report and this annoying thing will be fixed. Most of the time I wish I knew more about the workings of the engine to make better calls, and I sooooooooo appreciate your guys help, It's been great!
Jayme
Old 05-01-2007, 11:14 PM   #27
Tape's Avatar
just buy one if your buying, if you change it and still missing then put the one you took out and swap it to the next plug instead of buying them, I had a boot insulator cause mine $4.99 ea. Your bro is correct if no light then scanning will result nothing.
edit: geeesh, didn't know this thread was so old.
Tape is offline   Reply With Quote
Old 05-02-2007, 12:09 AM   #28
isnt there a way to check the coils by using a voltmeter or some other method?
-Thomas-
Old 05-02-2007, 12:27 AM   #29
If there was sand around the plug i would not go putting air to it
2004 mach 1 stock and staying that way.
Old 05-02-2007, 01:07 AM   #30
sure you can, just as long as you dont take the plug out first and let all that sand get into the motor............
-Thomas-
Old 05-02-2007, 10:12 AM   #31
Tape's Avatar
set the meter to ohm's and see if it's open, it will only be good or bad, not like some people think... "may be going bad"
Old 05-02-2007, 11:04 AM   #32
DarkShadow's Avatar
Send a message via AIM to DarkShadow
Yep. You must work at a parts store don't you?
Did we ever get this resolved?
DarkShadow is offline   Reply With Quote
Old 05-02-2007, 03:06 PM   #33
Tape's Avatar
nope, retired aircraft tech, I don't know if it was ever resolved but I did awaken the dead.. this is a couple of months old
Old 05-02-2007, 03:56 PM   #34
bullitt482's Avatar
Cool, what aircraft did you work on and what branch?
ADD FTW
01 Bullitt
Old 05-02-2007, 07:20 PM   #35
Tape's Avatar
ADD FTW
I started over there where you are in 1980 with the T-38 then to Blytheville Ark (not Blytheville now) on the KC-135R then to Alaska KC-135 then Shaw AFB on the F16's. Now I'm just a bum with no job and will stay that way til I'm a dead Bum
New Plug Wires Foxone Pre-2005 V6 Mustang 1 11-06-2009 06:19 PM
plug change rexracer General Mustang Discussion 2 06-28-2008 01:42 PM
Still Missin Justin 1979-1995 Mustang GT 9 10-27-2006 05:28 PM
Which damn plug? Feo Pre-2005 V6 Mustang 18 12-07-2004 12:18 PM
Help me figure out what this plug was for. Dom Mustang Audio & Video 9 07-14-2004 08:18 AM
06:35 AM
