Mis-Firing after cleaning... - Mustang Evolution
Old 03-18-2007, 03:09 PM   #1
USMCSS's Avatar
I sprayed down my engine today with a little degreaser and VERY lightly rinsed off with the water hose. Now, the car is mis-firing a little when I'm getting on the throttle hard in 2nd and 3rd. Anybody think I did permanent damage to a plug or coil pack or maybe something else?
Saleen #232
USMCSS is offline   Reply With Quote
Old 03-18-2007, 03:16 PM   #2
Re: Mis-Firing after cleaning...
sounds like you messed up a coil pack on top of one of your cylinders to me, dont use water on it. Clean it by hand every week and it wont get dirty enough to need water. If thats not it you can check your maf
Old 03-18-2007, 03:18 PM   #3
USMCSS's Avatar
Think the coil pack is toast? How will I know which one and are u referring mass air flow when u say "maf". Just making sure.
Saleen #232
Old 03-18-2007, 04:19 PM   #4
you have individual coils per plug, at least I think all 99+ do (i know 01 up does) and one of those might be out~ but it should do it ALL the time not just at a given rpm, it is worse when you get going more but it should be missing if its not working you can pull them and see which one makes it worse lol and you can find the one that is bad perhaps.
By MAF I mean the mass air flow sensor, but its probably fine if it runs at all.
Old 03-18-2007, 04:20 PM   #5
Zim
You want to **** me?
Zim's Avatar
Using water is fine... I spray my motor down all the time and have no problems. On the old cars it was bad to do cause they didnt water proof all the connections. Now all the electrical connections have rubber seals to keep water out. Its fine to do.
I like toys
Old 03-19-2007, 12:08 AM   #6
Thomas91169's Avatar
maybe there is water down in the plug galley grounding out the plug :dunno:
thats all i got
-Thomas-
Old 03-19-2007, 05:04 AM   #7
MonteCitan's Avatar
thats all i got
+1, they're just about vertical, and like to hold water... pull the coil packs out, check to see if they're wet on the base...
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 03-19-2007, 05:33 AM   #8
USMCSS's Avatar
Well, I drove it around for a while last night to give it a chance to try to let some of the water evaporate. Let it sit overnight and drove it this morning. All is well now. My guess was a damp coil pack or water down in the plug galley. Either way, my baby is back to normal. Now, maybe I can find another Vette to smoke today cause I killed one on the way to work this morning.
thanks for all the input guys. Lots of good feedback and seems we were all on the same page.
Saleen #232
Old 03-19-2007, 02:07 PM   #9
Water gets down around the plug and causes the misfire problem. That was definitely what your problem was.
-Matthew
90 LX Coupe
02 GT Convertible
03 F-250 PSD
06 SRT8 Magnum
http://www.tecmotion.ca
Matthew is offline   Reply With Quote
Old 03-20-2007, 12:42 AM   #10
1234's Avatar
Or 1 of the coils got wet it happens all the time. most of the time coils are mounts where water wont get to them so when it does they tend not to like it and will cause a miss
cleaning heads upton7 General Car Discussion 3 04-10-2010 10:05 PM
Is it me or is mis-badging 05+ stangs common place now...? SpectorV General Mustang Discussion 6 05-16-2008 08:41 AM
cleaning question shamdoodie Mustang Audio & Video 12 09-24-2007 12:43 PM
cleaning help!!!! millastang Pre-2005 V6 Mustang 3 06-21-2007 09:39 AM
Mis-spelling... KrazyPony ME Site Help & Announcements 4 12-20-2005 03:00 PM
08:29 PM
