weird clutch problem - Mustang Evolution
Old 09-09-2010, 07:43 PM   #1
Hello,
Ive got a 1997 mustang 4.6 5 speed with a clutch issue. I just got the car back after having a new throw out bearing installed. Also the flywheel was resurfaced and a napa adjustable clutch cable and solid quadrent was installed.
tonight while driving home my pedal got easyer to push in while shifting. i also noticed that the car would shutter on take off and while shifting. It alsmost seems to act like the clutch is still half enguaged with the pedal in.I also noticed the transmission is a little harder to shift.
Do you think the new cable might have stretched and needs to be adjusted? It only has about 200km on it?
rebel3.0 is offline   Reply With Quote
Old 09-09-2010, 07:58 PM   #2
02Nate281's Avatar
Send a message via AIM to 02Nate281 Send a message via MSN to 02Nate281 Send a message via Yahoo to 02Nate281 Send a message via Skype™ to 02Nate281
Re: weird clutch problem
You might need a firewall adjuster. Or a pedal height adjuster?
"There is no love without sacrifice"
02Nate281 is offline   Reply With Quote
Old 09-09-2010, 08:25 PM   #3
02Nate281's Avatar
There is a thread on this forum about that from a long time ago.
I found it here
If it doesn't help, someone here surely can. Most likely SpectorV, Herbstang, or lowflyn.
Old 09-09-2010, 10:18 PM   #4
thanks for the help
Weird trans problem, help! fast64 Pre-2005 V6 Mustang 1 11-28-2009 02:31 PM
weird vacuum problem jedwards242000 Pre-2005 V6 Mustang 7 05-04-2008 01:56 PM
Weird speaker problem fast64 Mustang Audio & Video 5 04-07-2008 11:31 PM
Clutch Problem! I think!! Scoot99V6Stang Pre-2005 V6 Mustang 5 03-21-2006 10:48 PM
Weird starting problem... lowflyn Pre-2005 V6 Mustang 13 10-28-2005 09:20 PM
07:26 PM
