How good is the 4.6 - Mustang Evolution
Old 09-16-2010, 07:58 PM   #1
How good is the 4.6
I was just wondering how good the 4.6 motor is thats whats in my gt.
TACTICALGLOCK is offline   Reply With Quote
Old 09-16-2010, 08:02 PM   #2
02Nate281's Avatar
Send a message via AIM to 02Nate281 Send a message via MSN to 02Nate281 Send a message via Yahoo to 02Nate281 Send a message via Skype™ to 02Nate281
Re: How good is the 4.6
Depends on what you do with it. Stock it is a great engine and it is very reliable if you keep it maintained.
Performance wise the 4.6 is as good as your wallet is thick. It has endless potential.
"There is no love without sacrifice"
02Nate281 is offline   Reply With Quote
Old 09-16-2010, 08:04 PM   #3
Just wondering i never owned one. I have heard them blowing spark plugs out.
Old 09-16-2010, 08:53 PM   #4
I have a 98 gt. Is this a single overhead cam.
Old 09-16-2010, 09:15 PM   #5
02Nate281's Avatar
Yep. It's a SOHC 2v engine.
Old 09-16-2010, 09:17 PM   #6
I think the single overhead cam is better than the double for reliability isnt it.
Old 09-16-2010, 09:20 PM   #7
02Nate281's Avatar
I've never had any experience with the 3v or 4v DOHC Mustangs. If PureVenom or SpectorV were online they could tell you more than I can.
Old 09-16-2010, 09:21 PM   #8
How has your single overhead cam engine been treating you.
Old 09-16-2010, 09:25 PM   #9
02Nate281's Avatar
It's awesome. I love it. 118K miles I haven't had any problems out of it since I bought it. I do run seafoam through the vacuum every 3 or 4 months to keep the intake, valves, and cylinders clean and I give it and oil change around every 5K miles.
Old 09-16-2010, 09:27 PM   #10
What year did the single cams come in.
Old 09-16-2010, 09:38 PM   #11
02Nate281's Avatar
I think they all had single cams until 96 when the cobra was released as a dual cam 3v engine.
Old 09-16-2010, 09:42 PM   #12
What year did they go to the dohc
Old 09-16-2010, 09:48 PM   #13
02Nate281's Avatar
In 1996 when the Cobra was first produced. From what I understand it was the first Mustang to sport a DOHC engine. So '96 was the first DOHC
Old 09-16-2010, 09:50 PM   #14
So if mine is a 98 how is it a sohc.
Old 09-16-2010, 09:51 PM   #15
Mine looks to be a sohc.
Old 09-16-2010, 09:55 PM   #16
02Nate281's Avatar
All GT Mustangs are single cam. All Cobra's are dual.
The GT has one intake valve and one exhaust valve.
The Cobra's have TWO intake valves and one exhaust valve.
Old 09-16-2010, 09:57 PM   #17
Ok. Thanks for the info. So they seem to be good motors i hope.
Old 09-16-2010, 09:59 PM   #18
02Nate281's Avatar
They are excellent motors. What is the reason for asking though?
Old 09-16-2010, 10:01 PM   #19
I have never owned one and i have heard people saying something about them blowing out spark plugs but not sure which year 4.6.
Old 09-16-2010, 10:11 PM   #20
02Nate281's Avatar
I've never heard of it until now. But it comes form the spark plug not being torqued down enough or torqued incorrectly. It causes the plug to become loose and then the compression in the cylinder forces the plug up, and the COP pushes it back down. With all the up and down movement it can eat the thread off and then the compression will blow the spark plug out when it's no longer held in by the threads.
You just have to make sure your spark plugs are tight enough when you change them.
Old 09-17-2010, 12:08 AM   #21
MonteCitan's Avatar
Correction to above.. all 4.6 GTs 96-2004 were SOHC.
2005-2010 GTs were SOHC also, but with 3 valves per cylinder instead of 2
96+ cobra/mach 1 4.6s were DOHC
There's no difference in reliability, it's all in how its driven, how its maintained, and the quality of work when upgrades are performed.
The 96-98 GTs were not the most stellar performing models, but that in itself makes it a sleeper.. A lot of 99-2004 GT guys will upgrade their heads and unload their "PI" heads pretty cheap.. and it's not a terribly expensive swap at a shop.. It is good for ~40-50 HP gain..
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 09-18-2010, 12:52 AM   #22
1ijack's Avatar
Send a message via Yahoo to 1ijack
I have 137,000 miles on mine and it treats me just fine I chaange the oile every 3500 iles and take good care of it to make it lasts.
The Mustang Mafia
"Join the family, if you dare"
www.themustangmafia.com
1ijack is offline   Reply With Quote
Old 09-20-2010, 04:52 AM   #23
Tape's Avatar
the plug blow out ain't a big deal, I fixed mine in less then a hour, no need to remove the head, #8 blew on mine, a good hint is if you hear a knocking under the hood check the plugs first. I have 150k miles on mine and running low 12's.
Tape is offline   Reply With Quote
Old 09-20-2010, 07:18 AM   #24
they are generally good cars, as with anything its all in how you take care of them. Those that run the piss out of them and then get butt hurt when they blow up... what did you expect would happen? Especially if they have many mods are are not tuned who knows if the car is super lean or what.
Blowing plugs out is generally an issue on the 4v and newer 3v motors with 300+ hp and higher compression (or boost).
Good Good laugh Cajun JungleBoy The Bar 8 06-17-2008 04:01 PM
Good place, good prices? crazeflier07 Pre-2005 V6 Mustang 6 11-09-2006 07:48 PM
It's up...and it's good!!!!! PureVenom The Bar 17 12-27-2004 10:09 PM
would this look good? Fishers Stang The Bar 4 11-16-2003 07:11 PM
06:13 AM
