04-22-2007, 11:27 PM
#1 | | Registered User
| 4.6 - 5.4 swap
Does anyone know if a a 5.4 modular will bolt in in place of a 4.6 in an '04 Mustang GT?
04-23-2007, 12:49 AM
#2 | | Legacy Member
| Re: 4.6 - 5.4 swap
not as easy as you think. i too was on the 5.4L/4V swap, but its not an easy task. i dont remember the entire list of parts, but its long. and its not a direct changeover.
-Thomas-
04-23-2007, 07:14 AM
#3 | | Terminator Owner
| Re: 4.6 - 5.4 swap
whats the main reason for wanting to do the swap other than saying you have a 5.4L engine. Just wondering if you might be going through the trouble for nothing.
__________________ 2003 Cobra Vert (Redfire) #3938 of 5082 @ 05/27/2003
472rwhp/493rwtq - Modification List - Dyno Sheet 2012 Mustang 3.7L M6 (Kona Blue) 2011 Ford Edge Sport (Red Metallic) |
04-23-2007, 07:15 AM
#4 | | Legacy Member
| Re: 4.6 - 5.4 swap
The swap is worth it for the torque difference if nothing else.
It is a very lengthy and complicated install however. It is a tight fit if you go DOHC...which is the only way I would go.
Mine: -03 SB Cobra vert- 2552 of 5082 Born 02/25/03
Our's: 90 7up vert - new project-07 DSG Focus -DD 335 |
04-23-2007, 12:28 PM
#5 | | Legacy Member
| Re: 4.6 - 5.4 swap Quote:
Originally Posted by lowflyn The swap is worth it for the torque difference if nothing else.
It is a very lengthy and complicated install however. It is a tight fit if you go DOHC...which is the only way I would go. | either way i think you need a different hood, i think if you go with the sohc 5.4 the manifold has clearance issues with the stock hood, if you go 4v im sure you will run into the same problem.
-Thomas-
04-23-2007, 12:41 PM
#6 | | Registered User
Originally Posted by Thomas91169 either way i think you need a different hood, i think if you go with the sohc 5.4 the manifold has clearance issues with the stock hood, if you go 4v im sure you will run into the same problem. | yeah you do a buddy of mine did this swap and ended up buying my old steeda cowl hood off of me
__________________  1989 5.0 - Mustang Brandy the NOW It can Barely Idle B**ch   1999 Jeep Cherokee Sport 4.0 - Yeah Its Gotta Baby Dick Lift |
04-24-2007, 05:35 PM
#7 | | Registered User
| Re: 4.6 - 5.4 swap
besides the the usual stuff you will need a different hood, different intake, 4.6 GT intake will not fit, and the truck intakes are not the best for horsepower. Eithet a 4.6 with adapters or custom intake. Custom headers. I think that might be it
__________________ 99 Atlantic Blue V6- SOHC 4.6 swap, Tremec 3650, 8.8 rear end/ Flowtech Ceramic LT headers, off-road x-pipe, Spintech side exit exhaust. K&N drop in filter, removed snorkel, 18x10, 18x9, Anthracite Bullitt Replicas 295-35's, 265-35's. Eibach Pro-Kit springs, M&M Camber Plates
04-24-2007, 05:43 PM
#8 | | Registered User
It is a very lengthy and complicated install however. It is a tight fit if you go DOHC...which is the only way I would go. | +1. Plus if the engine was out already, it would be getting bored and stroked. No point in removing a stock engine to put another stock engine back in.
01 Bullitt
10-12-2008, 07:22 PM
#9 | | Registered User
| Re: 4.6 - 5.4 swap
10-12-2008, 08:24 PM
#10 | | Legacy Member
| Re: 4.6 - 5.4 swap
^+1, birdman, ive seen u on mach1regisrty.com and u are one of my heroes lol. i am in the process of the 5.4 swap, i was going sohc, but now dohc because i found all my stuff for cheap. the 2v swap is not as hard as people think, the trannys bolt up and u have to extend some wiring for the 5.4. they make adapter plates for the pi intake to fit on top of the 5.4 and ull need a 8 bolt flywheel and matching clutch. the engine is taller but they make k-member spacers to lower the engine down. ull also have to modify the mid pipe. the 4.6 will not match the 5.4 in torque delivery so that alone is worth the swap. birdman actually has swap kits for the swap. ill actually pm u birdman w/ a few questions about your swap kit.
96 GT- Who knows what's in it.
10-13-2008, 05:34 AM
#11 | | Registered User
| Re: 4.6 - 5.4 swap
100% hand built 2004 Cobra (body in white)
Boss 330 built 5.4 32V NA
404/387
12-12-2008, 05:37 PM
#12 | | Registered User
| Re: 4.6 - 5.4 swap
Like a buddy told me lately, If you can put a 427 in a 72 Pinto (which I did), you can put a 5.4 into a Mustang which is made for the same engine family. The 5.4 is the same engine as the 4.6 with just a taller deck, just like the difference between the 5.0L (302) and the 351 windsor. So the block's a little taller and the heads will be a little higher too. Dropping the K member a couple inches and modifying the exaust a little and probably modifying the engine wiring harness are all things that can easily be done.
12-13-2008, 05:57 AM
#13 | | Registered User
| Re: 4.6 - 5.4 swap
a 5.4 2v swap is pretty direct. you will have to get intake adapters or the hps swap intake. the 5.4 will clear the stock hood with minor modification to the hood. no lt header is available, and if you are doing a complete rebuild then you have to buy a few things for the 5.4.
stock long block, bolt ons, and juice
N/A- 12.81@103.7
N2O- 11.79@115.8 |
03-28-2009, 03:00 PM
#14 | | Registered User
| Re: 4.6 - 5.4 swap
Another one on the road in Naples, Florida.
Completed a couple of weeks ago in a 98 Cobra.
Motor is very mild.
5.4 32V (01 heads), forged lower end, flat tops, FGT cams,
and the Aussie intake (modded) with the kit.
Vids are poor quality, (sorry)
camera has been acting strange lately. In process: Finished product: Bad quality vids (again, sorry, but the sound does work well)
404/387
04-15-2009, 04:03 PM
#15 | | Registered User
| Re: 4.6 - 5.4 swap
hmm I wish i could come across a GT500 setup for my car
04-15-2009, 05:12 PM
#16 | | Registered User
| Re: 4.6 - 5.4 swap
Very Nice Swap!
2003 Zinc Yellow Mustang GT
(Bone Ass Stock)
04-15-2009, 06:48 PM
#17 | | Registered User
| Re: 4.6 - 5.4 swap
looks good birdman, how much better does it feel from the 4.6 motor?
1996 GT (sold)
1997 Cobra
1993 Ranger GT (not broke)
Want an 03/04 Cobra
Born:5/23/97, Build # 5722 of 6961 Builds
04-15-2009, 08:15 PM
#18 | | Registered User
| Re: 4.6 - 5.4 swap
here is my swap its a 98gt with a 01 5.4 with a vortech V1 Strim charger
01-21-2010, 06:24 AM
#19 | | Registered User
| Re: 4.6 - 5.4 swap
404/387
01-21-2010, 06:25 AM
#20 | | Registered User
| Re: 4.6 - 5.4 swap
404/387
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | |
Similar Threads | | Thread | Thread Starter | Forum | Replies | Last Post | | 4.6 swap to a 5.4 | b's stang | 2005-2009 Mustang GT | 9 | 06-21-2010 09:26 PM | | Possible V8 Swap? | NeedSomeMods | Pre-2005 V6 Mustang | 5 | 05-18-2010 02:43 PM | | 5.8 swap ? | Z-EATER | 1979-1995 Mustang GT | 1 | 05-19-2008 05:29 AM | | To Swap, or not to swap...... | Strongarm | 1979-1995 Mustang GT | 5 | 02-05-2008 01:39 PM | | t5 swap | powerhungry966 | Pre-2005 V6 Mustang | 7 | 10-19-2005 08:18 PM | |
