changing the differential fluid - Mustang Evolution
Old 04-25-2007, 06:57 AM   #1
This seems pretty straight forward but I just want to make sure I have everything to do it. I know I'll need 3.75 pints of gear oil and I'll also need friction modifier. To reseal the diff is there a gasket or do I just use silicon? For that matter any specific silicon? Also can this be done without lifting the car? I could drive the car in reverse up onto ramps but I would think I would want the car to be level. Thanks.
-Denver
2002 Mineral Grey GT, 5-speed: MGW short throw, JLT CAI: SOLD
2002 Electric Green V6, Auto: SOLD
greenpony02 is offline   Reply With Quote
Old 04-25-2007, 07:18 AM   #2
Re: changing the differential fluid
Make sure you get the right weight oil (I cant remember right off.) Have the car level and up in the air enough to work under it. Then remove the rear cover and let the oil drain out. Once done wipe the bonding surface for the rear cover very good to help ensure a good seal. You can buy rear seals but most simply use silicon to seal the rear end. Put a good amount of silicon on the rear cover making sure to go around the inside and outside of the bolt holes on the cover. Carefully place it on the rear housing and bolt it down evenly. After you have all this done remove the fill plug located on the front of the housing and squeeze the lube into it. It can be hard to get to but you should be able to maneuver it if the rear end is hanging free while the car is jacked up.
You only need friction modifier if you have a traction lock or other positive traction style device if my memory serves me right.
Old 04-25-2007, 07:41 AM   #3
Thanks, Spec. I'm doing this on the GT so I do need the friction modifier. Does anyone know if I could just use Royal Purple 75W140 (that's the correct weight) Max-Gear oil instead of regular gear oil + the modifier? According to royal purple "All viscosities of Max-Gear are formulated with hypoid friction modifiers necessary for use in clutch or cone type differentials. No additional additives are necessary."
-Denver
Old 04-25-2007, 08:16 AM   #4
You can buy many brands of oil for the rear end that already contain friction modifier. I would just buy OEM fluid or the Royal Purple brand without it and add my own unless the amounts are enough to meet the specifications needed for the 8.8 inch rear end.
Old 04-25-2007, 08:17 AM   #5
Do you know what the OEM fluid is? Or are you saying buy it directly from Ford?
-Denver
Old 04-25-2007, 08:58 AM   #6
rydog's Avatar
Send a message via MSN to rydog
Yes 75W140 is fine I would use regular fluid and add a friction modifier
97 V6-GT40 turbo-42#rs-BA2800 MAF-4.10's & tlok-254rwhp-369rwtq
Turbo'd by-TMA Turbo(http://www.tmaturbo.com/)
Tuned by-Dyno Tuned Performance(http://www.dtpracing.com/)
rydog is offline   Reply With Quote
Old 04-25-2007, 10:13 AM   #7
Scut95's Avatar
just go to walmart or your local auto parts store and buy Vavoline in the correct weight. Throw that in with the friction modifier....it'll work just fine
Old 04-25-2007, 11:53 AM   #8
Thomas91169's Avatar
Royal Purple FTW! besides, it already has a friction modifier.
i just used a nice thick bead of RTV to reseal the case. i let it sit for a hour or two for the rtv to setup after i bolted the cover back down before i added in the gear oil. no leaks after ~6 months.
btw get a foot of vacuum/fuel hose thats the right size to fit over the nozzle of the bottle, and it makes filling up the diff 100x easier. you can just hold the bottle way up in the chassis and let it drain down by itself and just hang out while it does so.
-Thomas-
Old 04-25-2007, 02:14 PM   #9
While the cover is off you can replace it with one that has a drain plug and make the change much easier next time.
Old 04-29-2007, 12:32 AM   #10
Use 80/90 or 75/90 for the rear end.
-Matthew
90 LX Coupe
02 GT Convertible
03 F-250 PSD
06 SRT8 Magnum
http://www.tecmotion.ca
Matthew is offline   Reply With Quote
Old 04-29-2007, 11:52 AM   #11
-Matthew
Is there a reason you say this? Ford recommends 75W140.
-Denver
Old 04-29-2007, 05:34 PM   #12
You don't need 140W oil in there - that's way too heavy. If you read your manual, Ford recommend 80W-90 gear oil, Motorcraft Part number XY-80W90-QL. I prefer the Mobil 1 gear oil myself, which I think is listed as 75W-90.
-Matthew
90 LX Coupe
02 GT Convertible
03 F-250 PSD
06 SRT8 Magnum
Old 04-29-2007, 06:32 PM   #13
-Matthew
Originally Posted by Ford Service Workshop Manual
Fill the rear axle to the level shown, approximately 1.66-1.77-liters (3.5-3.75-pints) of lubricant, and install the filler plug.
Use SAE 75W-140 High Performance Rear Axle Lubricant F1TZ-19580-B or equivalent meeting Ford specification WSL-M2C192-A.
And my little "manual" that came with the car said the same. Maybe they changed the spec when they went to the 3650 transmission.
-Denver
Old 04-29-2007, 06:44 PM   #14
i need to change my rear fluid but.. i have to take the exhaust off and maybe more...
Old 04-29-2007, 10:35 PM   #15
I quoted from the fluid specifications page of the 02 Mustang manual. That car is equipped with the 3650, though the transmission won't make any difference to the fluid. My manual also indicates that 75W-140 is acceptable, but 80W-90 is what you should use.
-Matthew
90 LX Coupe
02 GT Convertible
03 F-250 PSD
06 SRT8 Magnum
Old 06-10-2010, 12:55 PM   #16
MustangMafia97's Avatar
Send a message via AIM to MustangMafia97
Which Gear Oil should I get synthetic or non, and should I get some with friction modifier already mixed in or not.
Nothing but Ford...Nothing but American Muscle
MustangMafia97 is offline   Reply With Quote
Old 06-10-2010, 01:24 PM   #17
You "should" be able to get to it by just dropping the exhaust, but, a couple of the bolts might be a beast to get to on the back of the IRS cradle. When I resealed mine, I had the entire IRS out of the car....so I just took the chunk out and messed around with it.
Old 06-12-2010, 12:03 AM   #18
OsirisGuy's Avatar
Closing this thread as it is three years old.
Mustang Mafia - try starting a new thread. New threads are perfectly fine and you will get a better response.
And I would think Spector figured out by now
OsirisGuy is correct
OsirisGuy is right
2002 Mustang GT
Differential size Foxone Pre-2005 V6 Mustang 9 07-16-2010 03:39 PM
Smell diff fluid or tranny fluid when I get on it? ajpturbo 1996-2004 Mustang GT 0 06-19-2010 09:26 AM
changing automatic transmission fluid 007z28350 Pre-2005 V6 Mustang 8 08-30-2009 01:25 AM
Changing transmission fluid electricstang Pre-2005 V6 Mustang 4 12-16-2005 02:11 PM
how much differential fluid does a mustang hold? Horse Pre-2005 V6 Mustang 5 12-26-2003 02:45 PM
01:53 AM
