Mach 460 Amp question - Mustang Evolution
Old 09-20-2010, 05:09 AM   #1
I have a 2003 Gt 'vert. I'm not getting any base out of the system. The rear soeakers seem to be wroking, but they've lost their thump. I checked all the fuses related to the radio and they are all OK. I suspect the Amps are shot. Can it be anything else?
joestang406 is offline   Reply With Quote
Old 09-20-2010, 07:27 AM   #2
Re: Mach 460 Amp question
did you have an after market setup, back in the day at least when installing new speakers and such they would have to bypass the stock amps~ if its all factory then a fuse or something could be to blame, but It would be more than likely that the speakers wouldnt work at all if the amp was not working right?
Old 09-20-2010, 07:47 AM   #3
It's all stock. I checked all fuses and connectors and everything seems to be OK. Thats what's confusing me. the speakers still work, but no bass.
I suspect the amps are gone because of the brilliant positioning of the amps in the convertible top's boot I just started to get water in from around the rear window. I suspect the amps got wet. that';s why I checked the fuses first.
Old 09-20-2010, 10:43 AM   #4
Mine is a 94 but I have the mach 460 setup, my stereo did the same thing and it wasn't the amps it was the head unit itself, installed a new cd player and everything worked fine.
Straublittleman is offline   Reply With Quote
Old 09-20-2010, 05:38 PM   #5
hmm.. Interesting. I turned the unit on and put a cd in and the amps seemed to work. So it's just the radio. Is that possible??
Old 09-20-2010, 05:44 PM   #6
Yup I'd change the radio sounds just like what mine did.
Old 09-20-2010, 05:52 PM   #7
That's wierd. But thanks for the info.
Old 09-22-2010, 11:22 AM   #8
SaleenFiend's Avatar
Check for lose wiring. The Mach System is a great factory audio setup and I was very upset when I found custom work on my 04 Cobra thus eliminating the function of the stock Mach sound System.
Old 09-25-2010, 12:54 PM   #9
I checked the wiring at the apms and they were all good and tight. Speakers are OK, because the all work. What's left?
Is tgere anything behind the head unit I should check?
Old 09-25-2010, 07:05 PM   #10
Go to a scrap yard and find a mustang with the same radio and change it if you want it to be stock.
"02 Mach 460 wiring question Gerry52 Mustang Audio & Video 0 09-08-2010 08:50 PM
I am looking for Mach 460 front speakers and rear amp a3705872 Mustang Audio & Video 9 11-07-2009 05:10 PM
WTB: Mach 460 amp greenpony02 Mustang Parts for Sale and Wanted 2 07-06-2007 07:46 AM
mach 460 charkelly9 Mustang Parts for Sale and Wanted 5 06-15-2005 11:55 PM
Question about the Mach 460 system lowflyn Mustang Audio & Video 20 10-11-2004 07:31 AM
02:07 PM
