Why get a tuner? - Mustang Evolution
Old 04-28-2007, 04:50 PM   #1
Why get a tuner?
I dont really understand what the tuner does and why u would get one. Could someone please explain to me? Who needs a tuner? Would a daily driver use one or someone that races? Car with or without mods?
Laser is offline   Reply With Quote
Old 04-29-2007, 06:48 PM   #2
Re: Why get a tuner?
A flash tuner reprograms your engine management system. A typical generic tune on a flash tuner will slightly enlean the mixture and increase the timing, as well as require you to run premium fuel. The reason these changes are made is to increase power of the car. Most of the flash tuners on the market provide a small amount of user adjustability for things like your rev limit, and gears. Additionally, most flash tuners provide the ability to read and clear OBDII codes and to datalog the car.
A Dyno shop can build a completely custom tune for your car on the dyno using their own software and a flash tuner. This type of tune up is much more effective than a generic tune, and is highly recommended once you have significant modifications.
If you have an 04 or earlier Mustang, and it is close to stock, a flash tuner may not offer the best return for your performance dollar. As you get further down the road for modifications, it becomes increasingly worthwhile. If you have an 05 or newer Mustang, I personally think a flash tuner may be worthwhile right out of the gate.
To give an example, on my 02GT, I gained 7 or 8 ft-lbs in the lower RPM range, and 6 or 7 HP in the upper RPM range, and nothing at the peak power point with a Diablo Predator on an otherwise totally stock setup. Frankly, that was better than I thought I would get without other changes, but a high flow cat X-pipe will do better for about the same money.
-Matthew
90 LX Coupe
02 GT Convertible
03 F-250 PSD
06 SRT8 Magnum
http://www.tecmotion.ca
Matthew is offline   Reply With Quote
Old 04-29-2007, 07:22 PM   #3
The computer basically controls your car and a tuner alters the factory specification (or parts of it) for optimized performance or what not. It can help greatly but generally it is best on highly modified cars or cars with a power adder.
Old 04-30-2007, 12:18 AM   #4
Thomas91169's Avatar
if you know what youre doing a simple handheld can net you some nice gains. otherwise just installing their tune isnt going to do much.
i have the timing maxed out and the fuel leaned up a bit on my diablo on my GT. i had the fuel leaned out all the way but due to the winter blend of gasoline (being 91 octane to boot) i started to get some pinging past 4500 at wot, so i added some fuel all around for good measure.
though with handhelds, the ecu will still try to override the settings. if the o2's see the mixture getting lean because you tried to take too much fuel away, it will still add more fuel in to compensate.
-Thomas-
Old 06-07-2007, 04:51 PM   #5
2002silverGT's Avatar
Send a message via AIM to 2002silverGT
not really any need to a tuner unless u plan or allready have a SC in ur car
2002silverGT is offline   Reply With Quote
Old 06-07-2007, 05:07 PM   #6
Y2E0L0L5OGWT's Avatar
thats not true, really you should have your car turned for any type of serious modifications you do to it (i.e. gears, removing your cats, etc.), but you get the most of those tuners when you use them in combination with a serious of upgrades, not just one thing like an intake...and it also depends on your car as to how badly you need a tune depending on how sensitive the ECU's are. The computer in my S197 is far more sensitive than that in your 02 or any other mustang for that matter. My car will run super lean without a tune even if i do something as simple as put an intake on it. So when you get a tuner really depends on what all you are going to do to your car and what kind of car you have...
Old 06-11-2007, 08:06 PM   #7
Send a message via AIM to whipster24 Send a message via Yahoo to whipster24
you can't make the most out of modifications unless you get a tune.
and you definitely need a tune if you go with any sort of power adder
"This year will go down in history. For the first time, a civilized nation has full gun registration. Our streets will be safer, our police more efficient, and the world will follow our lead into the future!"
-Adolf Hitler, 1935
whipster24 is offline   Reply With Quote
Old 06-11-2007, 08:13 PM   #8
FattyMcFaterson's Avatar
Send a message via AIM to FattyMcFaterson
You also need a tuner if you decide to put some 5.13 gears and 38.5" boggers on your stang... to make the speedo correct
Oh Snap! Baconz!
FattyMcFaterson is offline   Reply With Quote
Old 06-11-2007, 08:21 PM   #9
rydog's Avatar
Send a message via MSN to rydog
I always wanted to do that to a mustang
97 V6-GT40 turbo-42#rs-BA2800 MAF-4.10's & tlok-254rwhp-369rwtq
Turbo'd by-TMA Turbo(http://www.tmaturbo.com/)
Tuned by-Dyno Tuned Performance(http://www.dtpracing.com/)
rydog is offline   Reply With Quote
Old 06-11-2007, 08:31 PM   #10
The only real way to fully tune a car is via data logging and simply taking the time to get it right as each car is different. Strapping it to a dyno and getting it tunned in is not the best, but its all most do as most dont have the time to log all their driving habits etc etc.
Old 06-11-2007, 08:31 PM   #11
Or even better, they just released some 54" boggers. Those things are f-ing huge.... plus they are a little over 650 bucks each....
Oh Snap! Baconz!
tuner upton7 1996-2004 Mustang GT 13 02-21-2010 09:37 AM
Need a Tuner!! jdhog2003 2005-2010 Mustang GT 1 12-15-2009 01:31 AM
Which Tuner to Get? mxw1090 Pre-2005 V6 Mustang 5 06-19-2009 12:46 PM
Tuner GT773 2005-2010 Mustang GT 12 06-16-2009 03:41 PM
Tuner upton7 1996-2004 Mustang GT 2 05-16-2009 12:56 PM
10:32 AM
