new owner with brake questions - Mustang Evolution
Old 04-28-2007, 08:21 PM   #1
Angry new owner with brake questions
i am replacing the rear brakes in my recently purchased 97 gt convertable, how do i get the emergency cables off of the rear calipers , traveling back from florida i destroyed the passenger caliper and found out the salt wasnt nice on my brakes sliders froze up so just replacing pads rotors calipers since all are very rusty what advice can someone give me i have a manual but it doesnt say how if any adjustments for the emgernceybrakes , i have a vacume gun to bleed the brakes also so i hope that works
the stalloing point is the cables on the calipers , how to remove them and re install on new caliper
thanks
redconvert97 is offline   Reply With Quote
Old 04-28-2007, 08:27 PM   #2
Re: new owner with brake questions
If I remember correctly it is spring loaded onto the mounting clip, you just disconnect this...
Give me a second and I'll find a diagram somewhere.
Old 04-28-2007, 08:37 PM   #3
ok sounds simple enough the spring is quite strong is there any load to it tb whatch out for?
Old 04-28-2007, 08:39 PM   #4
is it the big coiled spring that puts the pressure on the lever? that the cable sits in?
Old 04-28-2007, 08:39 PM   #5
If it wasn't dark I'd go outside right now and look...as a matter of fact, give me a few minutes, I'll see if my fat head will fit under my car and make sure I remember right.
Old 04-28-2007, 08:45 PM   #6
Ok, after looking at it again.
1.Make sure you have the parking brake off.
2. Get a pair of good sized pliers.
3. Grab ahold of the end of the parking brake cable (the metal tip)
4. Pull towards the rear of the car and out of the lever.
5. Watch out because I've had the pliers hit me a few times doing this.
*Disclaimer* I don't know that this is the "proper" way to do this...but it has always worked for me.
Old 04-28-2007, 08:50 PM   #7
ok i will try that i thought that may be it so much rust was the salty air at the beach in bradenton seemed to really work on the exhaust system too all i want now is to be able to drive it monday to the shop
and to install tha cable back in the lever pull it back out and slide it into the slot ? sounds simple enough i saw in the manual about not letting the adjuster? whell unwind on the consule i didnt think that would happen since i am not emoving any cables im too old for this anymore , done restoring cars just want to drive them *S* thanks
Old 04-28-2007, 08:51 PM   #8
oh i have braken my nose with things flying off and hitting me in the face was a 1958 thunderbird in i remember right it bit me good always careful if i can help it thanks
New 08 Mustang Owner with Questions cruss Pre-2005 V6 Mustang 12 12-24-2008 12:22 PM
New '96 Mustang Owner has questions floridamba Pre-2005 V6 Mustang 4 03-23-2007 02:38 PM
V6 Brake Upgrade Questions Cope Pre-2005 V6 Mustang 16 02-16-2005 04:12 PM
07:41 PM
