air fuel not mixing right - Mustang Evolution
Old 05-03-2007, 01:14 PM   #1
Angry air fuel not mixing right
hey everybody whats up i have a 2000 mustang gt the engine block is from a 96 thunderbird 4.6 and the rest is still mustang, only difference is in the belt.it is bored 20 over has ported and polished heads cold air intake and a gorrila chip running through the ats sensor.sense this motor has been in it its run fine only the idle while in gear has been bumping from 600 to 400 rpm and in park from 1000 to 700.if your behind my car and smell the exhaust its smells like its mixing to rich any help would be very much appreciated
ps if i stop really fast it will die also if the wheels turned all the way sometimes
thanks
00gtconv is offline   Reply With Quote
Old 05-03-2007, 01:19 PM   #2
Re: air fuel not mixing right
Sounds like you need to ditch the chip and get a tuner to get your tune right.
Old 05-03-2007, 02:22 PM   #3
no it was doing that before i put the chip in
Old 05-03-2007, 02:23 PM   #4
nice *** car by the way
Old 05-03-2007, 02:39 PM   #5
Thomas91169's Avatar
sounds like the IAC to me. one of the biggest culprits in anything idle related is the IAC. take it off and clean it with some carb cleaner. might want to try spraying some electronic sensor cleaner (can be found at any autozone) into the maf to see if that helps any.
and yeah, time to get a real tune. wtf is a gorilla chip?
-Thomas-
Old 05-03-2007, 02:54 PM   #6
ok i know maf is mass air flow sensor where is the iac
Old 05-03-2007, 02:57 PM   #7
by the way a gorilla chip is the cheap way to burn your chip you have no control over the settings it just curves your air fuel ratios and changes your shift points for an auto but your right it was definitely a waist of money it only puts out about 15 ponys id say but it was only 35$ so i didnt feel to ripped
Old 05-03-2007, 03:47 PM   #8
MonteCitan's Avatar
oh.. it was one of those IAT resistors from ebay?
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 05-03-2007, 06:15 PM   #9
If you have a resistor in your IAC it is NOT a chip. Put it back like it was so you can gain gas millage and power back. Get a REAL chip.
Old 05-03-2007, 08:00 PM   #10
yes it was a at resisitor from ebay air tempature sensor dont buy one they suck but that still doenst tell me what the hell a iac is is that the same thing
Old 05-05-2007, 02:48 PM   #11
Tape's Avatar
Tape is offline   Reply With Quote
Old 05-10-2007, 12:57 PM   #12
thanks to everyone that helped although the iac was a little dirty it turns out the intake was leaking and a passengerside rocker arm wasnt torqued down right lot worse than i thought
Got ? For Install Of Air/Fuel Gauge TafoyaMNAA Pre-2005 V6 Mustang 26 06-16-2007 10:49 AM
Gauges air/fuel , boost ,etc for blowers sporter 2005-2010 Mustang GT 6 05-26-2007 01:17 PM
Mixing leaded and unleaded? jwyche 1979-1995 Mustang GT 23 05-13-2007 01:59 PM
help asap air/fuel ratio gauge install Rstang98 Pre-2005 V6 Mustang 8 03-06-2004 01:17 AM
Mixing BodyKit Parts. TrueStang01 The Bar 15 08-05-2003 09:32 PM
02:33 PM
