Can a mechanical water temp guege be installed. - Mustang Evolution
Old 05-16-2007, 05:48 PM   #1
I bought one of those cheap mechanical water guages from the parts store and have notice there is 2 spot on the intake it will fit. one behind the thermostat and one on the passenger side of the car in the fron of the manifold. So what do I do with the sensor I romove, and what does each sensor control...I noticed the one on the passenger side seems to control the stock temp guage.
Can I just replace that one?
or another option can I just run some wires over to the other sensor and have both set wired to one sensor.
I know there must be better ways of doing this but I am on a incredibly small budget for the next couple months and travel 100 miles a day to work. I have had over heating problems and just replaced the radiator and wanted to be able to monitor the temp a little more accuratly then stock
any info is appricated.
rob4292 is offline   Reply With Quote
Old 05-16-2007, 09:08 PM   #2
Re: Can a mechanical water temp guege be installed.
On my truck I simply replaced the factory one. It works fine, just remember the factory one is no longer working.
BTW, be sure to check your coolant level afterwards as coolant will leak from the sensor hole.
Old 05-17-2007, 01:56 PM   #3
WELL on the mustang it dont seem possible...not by replacing one of them sensors with a mechanical guages sensor. the car ran like crap, wouldnt start...finally started then smoked alot....geuss im back to the same old stock guage....unless anyone has any idea's.
Old 05-17-2007, 02:16 PM   #4
hottcobra's Avatar
you need to eep the shock sensor hooked up because the PCM needs to know the coolant temperature for the air fuel mixture. you have to find another port in the intake or buy a thermostat housing with port made on to it
IEQUUS water temp gauge , glow brand new mac sk Mustang Parts for Sale and Wanted 3 04-26-2007 06:33 AM
Mechanical Problem megax29 Pre-2005 V6 Mustang 15 07-27-2006 06:13 PM
Decided to keep Water Temp Guage Ibanezplayer272 1979-1995 Mustang GT 2 02-04-2006 04:52 PM
Autometer Pro-Comp Ultra Lite Water Temp Gauge Ibanezplayer272 Mustang Parts for Sale and Wanted 0 01-30-2006 02:01 PM
Autometer Lunar Water Temp Gauge FS stangin99 Mustang Parts for Sale and Wanted 0 05-16-2005 04:11 PM
» Members Mustangs
Lucy
ViperMKII
RED
Randl114
Add your Mustang
01:16 PM
