K-member question - Mustang Evolution
Old 09-28-2010, 08:27 PM   #1
DarkShadows's Avatar
K-member question
Ok so I had the car up on the lift to fix my axle issue. So I was looking under the car while it was in the air, noticed the k-member has weird notches on the passenger side mounting point but the driverside does not.
Here is the passenger side.
Driverside
Now I know that I have a knocking noise coming from the mid frontend (that's what it sounds like anyway). The bolts aren't loose or anything. I was just trying to figured if this is right for the kmember to have those slots.
Also just for the fun of it, here is the so called dry and non-leaky oil pan I have (acording to one of our ford dealers). Yea sure it isn't leaking, guess they were blind!
March 2010 Mustangevolution Mustang of the Month 1st eva biatch!
DarkShadows is offline   Reply With Quote
Old 09-28-2010, 08:39 PM   #2
Re: K-member question
is that an oil leak of some sort
zztop1234 is offline   Reply With Quote
Old 09-28-2010, 08:52 PM   #3
I honestly have never looked...next time I'm under one of the cars I'll take a look.
From looking at it they do seem to be normal and not something that has worn that way.
Old 09-29-2010, 08:28 AM   #4
Both sides have the notches it all depends on how the k member is adjusted as to whether the washer on the bolt covers it up or not. It looks like one side is push all the way forward/backward (can't tell from the pic) and the other is centered in the slot.
Old 09-29-2010, 09:08 AM   #5
SaleenFiend's Avatar
Sure it's not a rear main? I can't tell by the picture the location.
Beat me to it.... you can clearly tell from the picture that the driver's side is centered up on the slots while the pass side is completely pushed forward.
Old 09-29-2010, 10:33 AM   #6
Well I'm not sure man. The location is on the rear of the oil pan right by the trans. I'm just going by what the alignment shop saw and told me and now I see
Old 09-29-2010, 10:56 AM   #7
Yea, well honestly it looks to be the oil pan gasket I was just throwing that out there.
Old 10-01-2010, 06:59 PM   #8
edross's Avatar
Driverside
my car was making a knocking sound up front, shop put a impact wrench on those bolts and the sound was gone, didnt turn much but it did stop the noise
2003 gt, sct custom tuned by VMP, k&n fipk, upr o/r x-pipe, dynomax turbo mufflers, mm c/c plates, mm full length subframe connectors, h&r race springs, bullit rims 18x10 rear 18x9 front, 4.10 gears, 20% tint, 9 inch shorty antenna
edross is offline   Reply With Quote
New member chris r New Member Introductions & Greetings 9 09-29-2009 12:11 PM
New member MistaG84 New Member Introductions & Greetings 14 02-06-2009 01:08 PM
New member badvenm General Mustang Discussion 9 07-15-2008 07:54 PM
Yet another new member wthalliii New Member Introductions & Greetings 23 04-03-2007 08:30 AM
Question about Member Gallery?? 03ZincMach ME Site Help & Announcements 3 12-04-2005 02:28 PM
» Members Mustangs
Squat
5Point
Dorthy
Rcon127
Add your Mustang
08:19 AM
