Exhaust Leak Help - Mustang Evolution
Old 05-19-2007, 03:44 PM   #1
Exhaust Leak Help
What problems can an exhaust leak cause? Someone told me that I have a leak and I was wondering if it is something that needs to get fixed right away and if it is causing my idle problems.
97_GT is offline   Reply With Quote
Old 05-19-2007, 04:02 PM   #2
Thomas91169's Avatar
Re: Exhaust Leak Help
well if its pre-cats itll cause the exhaust to try to go out the leak area instead of going through the catalytics. if its a leak before the upstream o2 sensors (closest to the engine) the o2's wont read what they should and may throw a code. in that case the only place there could be a leak is between the manifold and downtubes.
can you hear a leak? when you get on it does the car sound like crap, like a high pitched raspy sound coming from under the car?
-Thomas-
Old 05-19-2007, 06:00 PM   #3
The guy at autozone said he thinks there is a leak but I dont know much about it. It lost its raspy sound and idles really high. Whenever I shift, the rpms stay at the spot i shifted at and fall really slow.
Old 05-19-2007, 08:40 PM   #4
the slow drop of rpm is a mustang thing. most of it due to the tune. unless yours drops extra slow...
you might try cleaning out your IAC and cleaning the maf for starters. take carb cleaner to the iac and electronic cleaner (usually next to the carb cleaner at autozone) and spray the maf with it. could be the throttle position sensor :dunno:
-Thomas-
Old 05-19-2007, 10:43 PM   #5
The rpms fall a lot slower than they used to and I already put a new AIC in so it cant be that. What else could it be
Old 05-20-2007, 03:13 AM   #6
Send a message via MSN to 1996stang Send a message via Yahoo to 1996stang
TPS sensor they are very cheap and only a plug and 2 screws holding them on.
2004 mach 1 stock and staying that way.
1996stang is offline   Reply With Quote
Old 05-20-2007, 08:41 AM   #7
Just get a new one?
Old 05-20-2007, 08:44 AM   #8
ridenmystang's Avatar
Get the crack welded. Its only like $20 at the muffler shop
One wicked 03 GT FOBRA
ridenmystang is offline   Reply With Quote
Old 05-20-2007, 11:49 AM   #9
Originally Posted by 97_GT View Post
Just get a new one?
If its bad get a new one.
exhaust
2001 Cobra fuel leak (I know wher3e the leak is) badcrc General Mustang Discussion 2 12-27-2008 11:54 PM
exhaust leak 98StangGT 1996-2004 Mustang GT 8 08-29-2006 03:38 PM
I have an exhaust leak... Ibanezplayer272 1979-1995 Mustang GT 19 12-15-2005 11:47 AM
exhaust leak mustangruss Pre-2005 V6 Mustang 22 12-10-2005 08:26 AM
exhaust leak Scorpion99 Pre-2005 V6 Mustang 1 03-27-2004 02:47 PM
01:56 PM
