SLOW IDLE RETURN - Mustang Evolution
Old 10-02-2010, 10:08 PM   #1
SLOW IDLE RETURN
I have a 98 mustang gt that the idle comes down slow. Any ideas what this might be.
TACTICALGLOCK is offline   Reply With Quote
Old 10-02-2010, 10:28 PM   #2
02Nate281's Avatar
Send a message via AIM to 02Nate281 Send a message via MSN to 02Nate281 Send a message via Yahoo to 02Nate281 Send a message via Skype™ to 02Nate281
Re: SLOW IDLE RETURN
You mean it drops RPM's very slow after revving it?
"There is no love without sacrifice"
02Nate281 is offline   Reply With Quote
Old 10-03-2010, 06:39 AM   #3
YES
Old 10-03-2010, 11:29 AM   #4
SaleenFiend's Avatar
Idle Air Control Valve or Throttle Position Sensor. Clean your throttle body first.
Old 10-03-2010, 04:45 PM   #5
I sprayed the throttle body but didnt help.
Old 10-03-2010, 05:57 PM   #6
i just put a new idle control valve on but didnt seem to help much.
Old 10-03-2010, 07:01 PM   #7
02Nate281's Avatar
Seafoam through the vacuum intake line.
Old 10-03-2010, 07:37 PM   #8
Do you mean the sea foam fuel additive or the sea foam spray for loosining bolts.
Old 10-03-2010, 09:24 PM   #9
02Nate281's Avatar
This stuff. It's not just a fuel additive. It can be put in the crankcase, vacuum lines, fuel lines, etc. I run it through the vacuum by letting the vacuum line suck it out of the can a little bit at a time while holding the throttle open. Try it and see how it works.
Old 10-04-2010, 05:54 AM   #10
WHICH VACUUM LINE.
Old 10-04-2010, 09:53 AM   #11
maf needs cleaning, iac needs cleaning/replacing, or the idle decay rate in the ecu is high (but it wouldnt have just started if it was this). Ive heard good things about sea foam as well
Old 10-04-2010, 10:13 AM   #12
It always either the TPS or IAC ... The IAC can make the car run really rich too. It doesn't hurt to do the Seafoam or clean the MAF but I doubt these correct the problem
Old 10-05-2010, 05:45 AM   #13
I have been hearing alot of mustangs doing this i was told it was normal something to do with pollution control.
Old 10-05-2010, 06:41 AM   #14
If it seems to hang up or take extremely way to long then it's not normal. It should drop about 500-1000rpms in a second or less continuously
Old 10-05-2010, 06:47 PM   #15
i replaced both sensors and no change.
Old 10-05-2010, 07:35 PM   #16
02Nate281's Avatar
Does it do anything else? Such as drop and rise in RPM's by itself while at idle? If it does that too, then you definitely have an exhaust leak. Check every hose and intake/vacuum line under the hood.
Old 10-05-2010, 07:37 PM   #17
no it idles perfect NO PROBLEM THERE.
Old 10-06-2010, 10:57 AM   #18
Do you have a stock throttle body?
And did you clean the throttle body?
Old 10-06-2010, 11:13 AM   #19
Stock throttle body and yes i cleaned it with sea foam.
Old 10-06-2010, 09:31 PM   #20
Get a towel or napkin or something and manually clean the TB at the plate while your opening and closing it. Get some brake cleaner and take the TB off and clean it with that till it's like new.
Old 10-07-2010, 05:49 PM   #21
its clean and looks new. I THINK ITS JUST NORMAL.
Old 10-08-2010, 07:34 AM   #22
Is this your first Mustang?
Old 10-08-2010, 10:40 AM   #23
I had a 1988 lx but this is my first 4.6 gt.
The return of the 5.0 Mustangfan2003 2011-2014 Mustang GT 31 01-06-2010 11:46 AM
When I return from vacation.... Brent ME Site Help & Announcements 13 08-14-2005 08:56 PM
finally got my return cjd10 Pictures and Videos 12 02-04-2005 06:08 PM
return of the camaro evilweirdo42 General Car Discussion 57 12-14-2004 02:55 PM
08:15 AM
