Rear end leak - Mustang Evolution
Old 05-27-2007, 07:37 AM   #1
Rear end leak
I seem to be leaking gear oil from the general region circled in this image. (the image is from a 2005+ because I couldn't find one from a 2002) Any thoughts on where it could be leaking from / what needs replaced?
http://www.mustangevolution.com/foru...?do=big&p=1414
-Denver
2002 Mineral Grey GT, 5-speed: MGW short throw, JLT CAI: SOLD
2002 Electric Green V6, Auto: SOLD
greenpony02 is offline   Reply With Quote
Old 05-27-2007, 11:07 AM   #2
Re: Rear end leak
That would be your front rear end seal.
Old 05-27-2007, 11:07 AM   #3
Re: Rear end leak
its the rear pinion seal, it shouldnt be to hard to change. You might have to pull the pumpkin out and the pinion to get to it but I hope not. It might just tab in after you remove the driveshaft, I cant remember off hand.
Old 05-27-2007, 11:50 AM   #4
rocknbronco's Avatar
Re: Rear end leak
A very easy fix.
rocknbronco is offline   Reply With Quote
Old 05-27-2007, 12:59 PM   #5
Re: Rear end leak
Originally Posted by rocknbronco View Post
A very easy fix.
What all does it entail? Anyone know of a how to?
-Denver
Old 05-27-2007, 01:43 PM   #6
Re: Rear end leak
Remove the Ujoin mark the drive shaft and Ujoin for proper alingment I use magic markers. Then pop off the seal lightly tap it into place refill the rear end and your done drive it around for a few mintued then check for leaks repeat if needed again with a lift and the proper tools it shouldnt take 15 minutes.
Old 05-31-2007, 03:04 PM   #7
bullitt482's Avatar
Re: Rear end leak
Stop eating at taco bell????
01 Bullitt
Old 05-31-2007, 03:58 PM   #8
Thomas91169's Avatar
Re: Rear end leak
i think that would be classified as a "blown" or "exploding" rear end, even as far as "grenading" your rear. Jack's Tacos will do this as well.
-Thomas-
Old 05-31-2007, 04:07 PM   #9
Re: Rear end leak
My stomach is to tore up right now for the Bell Hell
What rear end do I have in my 08 4.0? stangaroo Pre-2005 V6 Mustang 6 03-27-2009 05:09 PM
Rear End Gray Ghost 1979-1995 Mustang GT 6 03-22-2009 07:09 PM
2001 Cobra fuel leak (I know wher3e the leak is) badcrc General Mustang Discussion 2 12-27-2008 11:54 PM
Rear End megax29 Pre-2005 V6 Mustang 8 08-27-2007 07:19 PM
95 GT rear end? IFixAircraft 1979-1995 Mustang GT 6 08-31-2006 07:07 AM
08:40 AM
