4.6 swap in to f150 - Mustang Evolution
Old 05-29-2007, 09:19 PM   #1
Question 4.6 swap in to f150
i found a complete 4.6 DOHC with trans and rear end in the junkyard and picked it up cheap. i've got a 89 f150 that i want to drop it in. if anyone has any knowledge on this swap let me know.
monstr250 is offline   Reply With Quote
Old 05-30-2007, 01:43 AM   #2
Re: 4.6 swap in to f150
Sorry, but you may be a little hard pressed to find any info on the swap you are suggesting, and you may have to make stuff up as you go. Then you can share the information you have gathered with others.
Or you could just settle for a stroked 351 or something.
JROC is offline   Reply With Quote
Old 05-30-2007, 04:11 PM   #3
bullitt482's Avatar
Ummm... What?
I would thing that most of the stuff you would use is mustang front end stuff.
But I'd definately rather throw money at a 351W than a 4.6 DOHC.
01 Bullitt
Old 05-31-2007, 03:00 PM   #4
sweet2kstang's Avatar
Region: Arkansas
you will have to do a lot of modification! motor, trans, shifter linkages, driveshaft, ecu, tune, fuel delivery, gauges, exhaust,probably steering shaft, etc. etc.
stock long block, bolt ons, and juice
N/A- 12.81@103.7
N2O- 11.79@115.8
sweet2kstang is offline   Reply With Quote
The baddest f150 I have ever seen! sonic04edge Pictures and Videos 20 01-12-2008 04:21 PM
New 6 Door F150 bluemustang General Car Discussion 7 03-08-2007 02:54 PM
F150 Performance ?? pres_slappy General Car Discussion 5 09-19-2006 03:39 PM
Brent needs an F150... briansol The Bar 40 09-08-2006 11:23 AM
anyone see the new f150 commercial? Zim The Bar 1 03-14-2004 10:29 PM
05:34 AM
