Bleeding Brakes? - Mustang Evolution
Old 06-06-2007, 08:53 PM   #1
ridenmystang's Avatar
Bleeding Brakes?
Ok so we painted the calipers today put them back on bled the brakes and put more brake fluid in but I still have no brakes. Someone said there's some kinda tool we're suppose to use. Any clues on what the hec im doing?
One wicked 03 GT FOBRA
ridenmystang is offline   Reply With Quote
Old 06-06-2007, 09:32 PM   #2
Re: Bleeding Brakes?
How did you bleed the brakes?
And did the reservoir ever get empty?
Old 06-07-2007, 01:47 AM   #3
Kiljosh's Avatar
Yea if you didnt start with the caliper farthest from the MC than youll have air in the lines.
Old 06-07-2007, 09:45 AM   #4
Herbstang's Avatar
Here's a how to http://www.corral.net/tech/maintenance/brakebleed.html
Old 06-08-2007, 08:26 AM   #5
yeah we didnt start the fartherest from the mc........ so hopefully it will be fixed today.
Old 06-08-2007, 03:47 PM   #6
Thomas91169's Avatar
bleed it at the master cylinder.
are you using the vacuum hose/water bottle method? stick about 3' vacuum hose on the end of the shrader valve (make sure it fits on the valve nipple tight) and stick the other end in a crystal geyser bottle with brake fluid in it (or other bottle of your choice, hell even the brake fluid bottle works), open the valve and pump the brakes. air will be released into the bottle but when it sucks back in, only brake fluid gets pulled in.
if enough fluid came out of the lines while they are off, chances are air worked its way through the system. do the same as above but from the master cylinder valves.
-Thomas-
Old 06-11-2007, 08:09 PM   #7
k so I took my car to get new brakes on it and after the new pads were put on it still didnt brake right come to find out its the master cylinder thats bad. Anyone want to buy a fobra Im about tired to dishing out mula
Old 06-12-2007, 12:43 PM   #8
how do they know the MC is bad?
btw your car sounds worse off than mine. makes my gsx look like a honduh.
-Thomas-
Old 06-12-2007, 03:02 PM   #9
FattyMcFaterson's Avatar
Send a message via AIM to FattyMcFaterson
Did you take the reservoir cap off the master cylinder when you were bleeding the brakes? And you do have ABS correct?
Cause if you dont take the reservoir cap off when you bleed brakes with ABS it can mess up your master cylinder.
Oh Snap! Baconz!
FattyMcFaterson is offline   Reply With Quote
Old 06-12-2007, 04:57 PM   #10
bullitt482's Avatar
/\ This is VERY true.
01 Bullitt
Old 06-12-2007, 05:14 PM   #11
Yeah, I know about ruining a master cylinder from personal experience. I was 16, changing the brakes on car for the first time ever. Pop, hey, now i have to pay 150 bucks to get someone to replace my master cylinder cause i dont have the time to do it myself while im in school and working.
Oh Snap! Baconz!
BRAKES DMAC General Mustang Discussion 5 02-18-2008 08:26 PM
Brakes mongolchuck 1979-1995 Mustang GT 1 01-12-2008 03:49 PM
brakes.. Fishers Stang Pre-2005 V6 Mustang 14 01-13-2005 06:32 PM
Brakes V6STANG007 Pre-2005 V6 Mustang 23 10-13-2004 04:32 PM
Brakes....... SexyStang Pre-2005 V6 Mustang 3 05-05-2003 09:03 AM
12:31 PM
