Bassani X pipe - Mustang Evolution
Old 10-06-2010, 08:27 PM   #1
04_GT's Avatar
Bassani X pipe
Ok so I have Borla stinger cat back and I am looking to get the bassani off road x pipe. I am just curious if there will be a problem with the noise inside the cab will highway driving since I wont have my cats. Just wondering Thanks
Borla Stinger Cat-Back, Cold Air Intake, 70mm Throttle Body, Underdrive Pulleys, Diablo Predator Tuner, H&R Lowering Springs, Tokico Shocks/Struts, Mach 1 Chin Spoiler, Smoked Taillights
04_GT is offline   Reply With Quote
Old 10-06-2010, 08:32 PM   #2
Re: Bassani X pipe
What rpm do you usually cruise at? I know when Im at 3k on the interstate it starts to get a little annoying after an hour or so and thats a v6. Under 3k Id say youd be just fine.
tigerfan2771 is offline   Reply With Quote
Old 10-10-2010, 07:49 AM   #3
edross's Avatar
Re: Bassani X pipe
when i changed to a upr off-road x-pipe it was twice as loud, i took the flowmasters off and put dynomax turbo mufflers on. its going to be loud
2003 gt, sct custom tuned by VMP, k&n fipk, upr o/r x-pipe, dynomax turbo mufflers, mm c/c plates, mm full length subframe connectors, h&r race springs, bullit rims 18x10 rear 18x9 front, 4.10 gears, 20% tint, 9 inch shorty antenna
edross is offline   Reply With Quote
Old 10-14-2010, 08:43 PM   #4
Re: Bassani X pipe
I rode in jimmy_beaner's GT for about 3 hours consecutively with his o/r x-pipe and borlas whaling and it never bothered me
It's definitely going to be louder, and whether it will be annoying depends on you. Me personally, hell no, but for some it might. As said on the highway the rpms are higher but usually that 5th gear (OD) relieves the noise level a bit.
Put it this way, if you want to be loud and proud all the time, get the o/r x-pipe. If you want to hear your music and have a conversation while on the highway...get a catted mid pipe...unless you like your music maxed out and consider yelling a conversation
Bassani Exhaust bcfhigdon 2011-2014 Mustang GT 4 07-06-2010 06:13 PM
Bassani or magnaflow? 01 PR RAGTOP 1996-2004 Mustang GT 17 03-25-2009 04:09 PM
Bassani Exhaust Seph Pre-2005 V6 Mustang 9 10-27-2004 01:44 AM
bassani exhaust greenpony02 Pre-2005 V6 Mustang 10 03-25-2004 05:54 PM
08:31 AM
