New shocks - Mustang Evolution
Old 10-13-2010, 12:12 PM   #1
04_GT's Avatar
New shocks
Ok so im about to buy either the Eibach pro damper set or the Tokico set of shocks and struts. My question is my 04 gt has the mach sound system with the subs and amp rack in the trunk. How much of a pain will it be to change my rear shocks with those in there.
Borla Stinger Cat-Back, Cold Air Intake, 70mm Throttle Body, Underdrive Pulleys, Diablo Predator Tuner, H&R Lowering Springs, Tokico Shocks/Struts, Mach 1 Chin Spoiler, Smoked Taillights
04_GT is offline   Reply With Quote
Old 10-13-2010, 01:17 PM   #2
SaleenFiend's Avatar
Re: New shocks
Not a pain at all. All you have to do is pull the clips holding the carpet/plastic down over the wheels (in the trunk), fold the carpet out the way and I suggest using an impact to undo the bolts in the trunk.
Slide under the car and undo the two bottom bolts... reverse for install.
Old 10-14-2010, 08:47 PM   #3
Re: New shocks
Do you have the Mach 1000?...with the 2 actual subs in the back. I wouldn't think that those would be in the way too much...might make for a tighter squeeze between them and the amp rack across the underside of the trunk.
Old 10-14-2010, 09:12 PM   #4
Re: New shocks
Once you pull the rear carpet you'll realize just how easy they are...
Old 10-15-2010, 01:26 PM   #5
04_GT's Avatar
Re: New shocks
Ok yeah I know its under the carpet i just didnt know if ford made it to where i would need to take out the rack to get the carpet off
Old 10-15-2010, 02:21 PM   #6
Re: New shocks
No, just the carpet/plastic over the wheel wells
Shocks? mitch Pre-2005 V6 Mustang 1 06-16-2007 09:58 AM
shocks and struts all8280bcc 1996-2004 Mustang GT 8 03-01-2007 12:49 PM
Shocks Struts megax29 Pre-2005 V6 Mustang 11 07-12-2006 09:34 PM
Shocks iceman08 Pre-2005 V6 Mustang 5 05-10-2006 07:53 AM
Shocks n8r Pre-2005 V6 Mustang 1 06-14-2004 10:52 PM
12:28 PM
