Steering trouble - Mustang Evolution
Old 06-29-2007, 06:14 PM   #1
Steering trouble
New here and wanted to see if you guys might have some advice on my problem. I have a 2001 GT. It was lowered when I bought it, not sure how much or what brand springs were used. It has 18's on it and I have had the alignment checked twice, all good. The problem I am having only occurs while backing up and turning the wheel in either direction. It feels like the wheels are trying to walk away from each other until one breaks loose and pops back in line, not sure if that makes sense. I was thinking maybe it was from the lack of camber adjustment with the lowering springs. Anyway, you can hear and feel it when the tire pops back in line, and when I start rolling forward the problem quits. Thanks for any help.
flynlowr1 is offline   Reply With Quote
Old 06-29-2007, 06:57 PM   #2
Re: Steering trouble
It sounds to me like (if its the front end) that the tire is hitting the front sway bar or the A Arm. You should be able to look under there and tell. Is the tire that pops and jumps the one that is pointed inward?
Old 06-29-2007, 07:23 PM   #3
Yes, the best that I could tell it was the tire that the front was pointed inward. However, it does this no matter how for the wheel is turned. It is not greater at max. turn.
Old 06-29-2007, 09:08 PM   #4
Take a look in the wheel well with the tire off and look for rubbing places and such. Measure from the ground to the top of the wheel well and also measure the distance from the top of the tire to the wheel well and we can see how low it is or take a pic.
Old 07-19-2007, 03:24 PM   #5
look to see if the wheel touches the fender wall
Maxion$mulla$ is offline   Reply With Quote
Too much trouble? upton7 1996-2004 Mustang GT 4 07-15-2009 08:31 PM
So...how much trouble am I going to get into? lowflyn The Bar 12 04-14-2009 06:33 PM
Reporter In Trouble Brent The Bar 6 07-11-2007 05:22 PM
Looks Like some of us are going to be in trouble!! ComputerGuy The Bar 23 01-16-2006 08:49 AM
Floormat Trouble Cope Mustang Audio & Video 10 02-02-2005 10:57 PM
09:10 AM
