Heads question - Mustang Evolution
Old 10-19-2010, 01:12 PM   #1
99 SVT Cobra's Avatar
Heads question
Well I took the cobra in and it turns out I need new heads and it is going to cost me $3600+ to replace it all to factory, thats what it is now. I found these performance heads cheaper:
FORD RACING HIGH-FLOW 4.6L DOHC 4V MUSTANG COBRA CYLINDER HEADS 03-04 Mach 1 Ford Mustang
Does anyone know with these heads would I have to upgrade my cams and everything? I think it would be worth it. Just asking for everyone's opinion. I figure if I am going to dish out close to $4000 I should at least get some performance out of it.
Bassani Off-road X-pipe, Magnaflow Catback, BOMZ Racing CAI, Smoked Tail lights, Black Projector Headlights
99 SVT Cobra is offline   Reply With Quote
Old 10-19-2010, 03:07 PM   #2
02Nate281's Avatar
Send a message via AIM to 02Nate281 Send a message via MSN to 02Nate281 Send a message via Yahoo to 02Nate281 Send a message via Skype™ to 02Nate281
Re: Heads question
You would probably have to get the camshafts with higher lift. That description keeps saying 4V Cobra... I thought the Cobra was a 3V engine. In any case, if you're upgrading your heads, it would be a perfect time to upgrade the cams also. So you don't have to go in there later on.
"There is no love without sacrifice"
02Nate281 is offline   Reply With Quote
Old 10-19-2010, 06:12 PM   #3
Re: Heads question
Thanks, well I know the 99 is a 4 Valve.
Old 10-20-2010, 06:21 PM   #4
Re: Heads question
Originally Posted by 02Nate281 View Post
. That description keeps saying 4V Cobra... I thought the Cobra was a 3V engine. ..
Becuase it is....Dude you are confused about a lot of things.
ajpturbo is offline   Reply With Quote
Old 10-20-2010, 08:05 PM   #5
Re: Heads question
If I am not mistaken I think the GT Mustang is the 3V.
Old 10-20-2010, 08:32 PM   #6
02Nate281's Avatar
Re: Heads question
From what I've heard/read, the factory spec 05+ GT's have 3V motors, 03-04 Mach 1's had a 4V, and the 03-04 Cobra had a 3V motor. The 99 Cobra apparently had a 4V motor.
And the only ajp turbo I've ever heard of is the kit made for a Honda Civic, having absolutely nothing to do with a Mustang OR Ford.
Old 10-20-2010, 09:10 PM   #7
Re: Heads question
honda civic si
honda civic
thats all the cars they make kits for
Straublittleman is offline   Reply With Quote
Old 10-20-2010, 09:12 PM   #8
02Nate281's Avatar
Re: Heads question
Originally Posted by Straublittleman View Post
Evolution VIII / IX
Evolution X
Genesis Coupe
SRT-4 Caliber
SRT-4 Neon
None of which have anything to do with Mustangs.
Old 10-21-2010, 04:32 AM   #9
Re: Heads question
My AJP turbo civic is what I smoke mustangs in. I enjoy my mustang too, in it's own sloppy american kind of way. I like to get sideways....can't do that in my civic. But it does run 11.90 WITHOUT slicks and uses pump gas.
It's just an avatar it doesn't have to be mustang related.
Old 10-21-2010, 12:55 PM   #10
01snakebite's Avatar
Re: Heads question
Just to clear things up on the cobra the 1996-2004 cobras all had 4V in them the mach 1 has the 96-98 4V with 305 hp as for the 1999 and 2001 have the 320 hp 4V the 2003-2004 is also a 4V but has better heads on it. The 3V came out in 2005 and was in the car untill the end of this year
2001 Cobra got to love the ride
01snakebite is offline   Reply With Quote
Old 10-21-2010, 03:08 PM   #11
upton7's Avatar
Re: Heads question
[QUOTE=02Nate281;798165]I thought the Cobra was a 3V engine.QUOTE]
Dude. No.
Old 10-25-2010, 11:50 AM   #12
SaleenFiend's Avatar
Re: Heads question
Where are you guys getting this info? 2005+ GTs are 3V motors. 2004- GTs are 2V motors. 1996-2004 Cobras are 4Vs (I'm not being rude)
This
Old 10-25-2010, 11:51 AM   #13
Re: Heads question
Why do you need heads? Can't get the machine shop to fix'em? What happened to the car?
Old 10-25-2010, 07:39 PM   #14
silverstangboy's Avatar
Re: Heads question
good question
A normal rebuild is just a shave and some cam bearings correct?
93 mustang notch
~450hp 331 stroker - Sold
Old 10-26-2010, 09:34 PM   #15
Re: Heads question
Thats just what they are telling me that my compression is low on cylinder 6 so I need heads. I know it could be more than the heads. I think it is time I garage it and start to rebuild the engine the way I want.
Old 10-26-2010, 09:59 PM   #16
Re: Heads question
The only way heads will make your compression go down is a burnt valve or head gasket maybe a crack but if it didn't run hot I'd say no crack. I'd get a second oppinion before I spent the money on heads if it has burnt valves I'd just upgrade the valves.
Old 10-27-2010, 05:24 PM   #17
Re: Heads question
Yeah thats why I am just going to park it and start working on it on my own. Check the heads, the valves, gaskets, piston rings, and so forth. Start upgrading see how it turns out.
heads upton7 1996-2004 Mustang GT 3 09-22-2009 11:21 PM
heads 05+ 4.0L V6 2007STANG Mustang Parts for Sale and Wanted 1 07-22-2009 12:02 AM
FS: BV Heads, 173's,Cam, and Stock Heads petrey10 Mustang Parts for Sale and Wanted 4 06-26-2006 11:15 PM
heads 93stanger 1979-1995 Mustang GT 12 05-24-2006 08:05 PM
4.2 heads question I_luv_HP&trq Pre-2005 V6 Mustang 3 09-13-2005 05:33 PM
11:59 AM
