I want to put a piller pod in the stang but dont know how i need help. - Mustang Evolution
Old 10-27-2010, 07:25 PM   #1
I want to install a pod in the car with a temp guage and oil pressure but dont know were to put the wire. i want to run both guages with stock ones. ITS A 98 gt.
TACTICALGLOCK is offline   Reply With Quote
Old 10-27-2010, 10:35 PM   #2
Re: I want to put a piller pod in the stang but dont know how i need help.
Well the oil pressure is easy you get a T fittng and unscrew your oil pressure sending unit and screw the T fitting in its place then srew your sending unit back in and screw your gauge line or sending unit "if is a electric gauge" in the other end.
The temp gauge I'm not to sure about but I know the v6 has a plug in the heater hose piping that you can put a gauge there.
Straublittleman is offline   Reply With Quote
Old 10-28-2010, 05:36 AM   #3
Were are the fittings located.
Old 10-29-2010, 01:16 AM   #4
Your oil sending unit should be buy your oil filter, and the temp gauge should be near your thermostat housing or top radiator hose. The T fitting you'll have to get at a parts store or hardware. If you can try to find a parts store that has people that know about cars and I know thats hard to find sometimes.
I'll try to help the best I can but I own a v6 not a 4.6 and don't really know where every thing is on the 4.6.
Old 10-29-2010, 07:20 AM   #5
if you have no purchased your items yet do not buy mechanical gauges, buy electrical.
Old 10-29-2010, 07:33 PM   #6
I am getting electrical. JUST NOT SURE WERE TO GET THIS T FITTING.
Old 10-30-2010, 02:31 AM   #7
This is an example buy very similar.
instead of the brass fitting poining upwards you would screw in your sending unit for your gauge.
Old 10-30-2010, 02:46 AM   #8
here is a link that might help to
http://www.newyorkmustangs.com/forum...ges-t4018.html
Old 10-31-2010, 11:02 PM   #9
Did you ever figure anything out? Did my advice help, I hope it did?
cd player pod upton7 The Bar 4 01-12-2010 08:54 PM
gauge pod upton7 1996-2004 Mustang GT 9 12-01-2009 01:54 PM
another "dont" when customizing a stang Kyle The Bar 10 06-16-2005 12:46 PM
WTB: driver side charcoal a piller blownsix Mustang Parts for Sale and Wanted 0 05-20-2005 03:42 PM
Stang needing to be put down PureVenom The Bar 19 03-19-2005 11:22 AM
12:27 PM
