low comp #'s - Mustang Evolution
Old 10-28-2010, 06:30 PM   #1
low comp #'s
im not really sure whats wrong wit my motor comp number just seem odd to me and dont really jump up if i add oil and retest its a got about 110k on it
#1 100 #2 80 #3 95 #4 175 #5 150 #6 145 #7 90 #8 100
4.65speed is offline   Reply With Quote
Old 11-04-2010, 05:11 PM   #2
bryanbrock's Avatar
Re: low comp #'s
hurtz rental mustang?! sounds like its got about 110k mi of strait yeehaw on it ....seafoam it, engin flush it REALLY well, go with higher grade oil, add a can of engin restore, seafoam it again just to make sur its done well, then change the plugs as they will be full of nasty **** that the engin is getting rid of from the seafoam, then add a bottle of octain boost to your PREMIUM gas then take her on a spin. YOU WILL FEEL THE IMPROVEMENT .....this will cost you about 50 bucks and an afternoon.
bryanbrock is offline   Reply With Quote
Old 11-04-2010, 05:39 PM   #3
Re: low comp #'s
thanks for trying but i really dont think restore will fix it altho i have never tryied that ****
Old 11-05-2010, 03:41 PM   #4
bryanbrock's Avatar
Re: low comp #'s
I said seafoam it TWICE,flush the engin REAL GOOD, change the oil to higher grade ..preferably a high mi formula AND also add engin restore, change the plugs, fill it with premium gas and add octain boost. this is WAY more than just adding the restore. this is not a merical cure but helps tremendusly and improvement will be noated. have delt with theas issues before and this is the best solution whith out getting drastic. good luck
Old 11-05-2010, 03:52 PM   #5
Re: low comp #'s
um ok like i said thanks for trying but i really dont care about restore nor will i use it
Old 11-05-2010, 08:02 PM   #6
Re: low comp #'s
Sounds to me like it's time to pull the heads and have a look. Could be a number of things.
Old 11-06-2010, 05:51 PM   #7
bryanbrock's Avatar
Re: low comp #'s
Agreed! he can either rebuild it, replace it, or sell the car. thats all there is if your not willing to put some effort into additives.
STAGE 2 COMP CAMS SLPRTMASON 1996-2004 Mustang GT 2 05-20-2010 06:10 AM
Finally Pictures of the New Comp Brent Pictures and Videos 13 02-01-2007 08:02 PM
Can't activate Windows on new comp Brent The Bar 17 01-03-2005 01:47 PM
12:56 AM
